XFX GeForce 8600 GT [PV-T84J-UDD3 V5.0] – recap information and shenanigans
  • Fast Alpha
    • Feb 2013
    • 245
    #41
    Re: XFX GeForce 8600 GT [PV-T84J-UDD3 V5.0] – recap information and shenanigans
    Does it matter what the solder is like when you added the new caps?
    What if the soldering is messy, do you use a solder fume extractor with the flux fumes?
    http://www.hse.gov.uk/pubns/indg305.pdf
      master hoarder
      • May 2008
      • 12176
      #42
      No, not really.
      This card has slightly tougher ground/Vcc planes on some of the caps, so the solder may appear harder to melt on those... in which case, adding fresh 60/40 solder may help. I personally don't care, as my soldering station I use for recaps is rather insensitive (70W of power, and using a 5.2 mm bevel tip). I also use flux-less 95/5 Sn/Sb (95% Tin, 5% Antimony) lead-free solder for coper pipes, which I don't recommend to anyone at all. It's very hard to melt, unless you have a good iron. I just use it because I have it. For flux, I have some leftover Kingo stuff, which isn't great, but it works OK.
      If you add enough flux, it shouldn't be.
      Do you use a solder fume extractor with the flux fumes?
      Nope.
      My nose is typically the fume extractor.
      Just kidding. I turn on the ceiling fan and open the windows for a bit while soldering. Good enough.
      • Nagy Daniel
        Lowest possible resistance on laptop motherboard rail - Guide Table request
        by Nagy Daniel
        Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
        I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
        I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
        So, I generated a table with AI so I can...
        03-04-2025, 08:24 AM
      • Victor Moreira Silva
        Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
        by Victor Moreira Silva
        I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
        Well, my decice specs are the following:
        Model: Acer Nitro 5 AN517-54-55T5
        CPU: Intel Core i5-11400H
        GPU: NVIDIA GeForce GTX 1650
        Motherboard: GH51G LA-L181P Rev:1c
        The symptom:
        When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
        05-26-2025, 10:49 AM
        no-name Radeon 9600 XT recap and cooler
        by momaka
        I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
        This one was actually suggested to me by ChaosLegionnaire....
        11-06-2020, 07:54 PM
        by momaka
        03-15-2023, 10:17 PM
      • lefetylorant
        Lenovo Thinkcentre tiny M90Q gen 1 - no 12V rail
        by lefetylorant
        Hello Everyone,
        Long story short, I got this unit for very cheap.
        I've started to experiment with it's BIOS, as I did before successfully with an M900. However my very bad quality SOIC clip broken while dumping of the biosof and it must have damaged something on the panel, because it does not turn on, and does exactly nothing when powered. The maximum voltage that could have affected something is the 3.3 or 5v from the IC clip, because the unit was not powered while the bios dumping was in progress.
        I've performed some measurements:
        - 20V rail perfectly...
        09-14-2023, 05:05 AM
