Question on one cap of DELL SX270
  • axlmastr
    • Aug 2005
    • 158
    I've enjoyed great success in repairing these machines all the way back to the GX50 series with the bad cap laden HI PRO psu. (350 units so far and 65 PSUs since 2003- all for small businesses) I got some more SX270s in the other day and to my dismay have run out of caps for the one (1) 1000uF 16V. I was wondering if I could get away with using a 1200uF 16V without any adverse effects. All things will be equal except the value rating. I know I have to order some more bulk, but to get htis last machine out can I get away with it. Tomcat, kc8adu, willa?
    Thanks in advance. .
    Glad to see you are offering the cap kit for this machine for those whose have been plagued with the DELL syndrome. I've been buying bulk since day one. Some of the Compaq towers and Gateway/Emachines have been rather fun as well. Anyone encountered the DELL GX PSU problem I've posted on in the past? Fans & caps have to be replaced just like the NetVistas I posted about also. Don't you just love Chinese crap? I love going to Fry's and looking at all of the ECS crap with the OSTs on them. And the US gov't thinks an economic stimulus pkg. will fix the economy. Read the love note the IRS sends you and understand it's classic redistribution of wealth people! It's not your money! Why not try keeping our business in the US where it was once made and done right instead of sending it to third world countries who don't share our ideals? If you spend your money at any major retailer or even for fuel it all goes to support those countries' economies not ours. That's called a trade deficit! (off my soapbox)
  • stevo1210
    • Oct 2006
    • 4156
    Re: Question on one cap of DELL SX270
    You can use the 1200uf 16V cap in the place of the 1000uf 16V cap because the capacitance is in a 20% range.
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • Akhlz001
      by Akhlz001
      09-20-2025, 07:15 PM
    • master3112
      by master3112
      07-29-2025, 01:55 PM
    • F R 2568
      Dell Latitude 5420 does not start (no post) need help to find the reason why
      by F R 2568
      Hello all,
      this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
      I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
      If the laptop is only connected to the AC adapter (battery removed):
      When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
      The power/battery...
      01-08-2025, 05:45 AM
    • diamon
      Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
      by diamon
      I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
      Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
      Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
      Pictures of these boards:
      Dell Latitude 5520 https://www.ebay.com/itm/256052956663
      Dell Latitude 5530 https://www.ebay.com/itm/125844181534
      Dell...
      02-28-2024, 12:51 PM
