Dell GX260 recapping?
  • dmahalko
    • May 2005
    Is there a capacitor list for the Dell GX260 motherboards?
    I've been looking around on this board but I've not seen much mention of what's needed for recapping GX260's.
    It looks like I have about 25 machines that are going to need this.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Re: Dell GX260 recapping?
    I'd be curious as well. I havent seen a 260 in a while, so I'd like to know what they take, so I can make kits for them.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • AlmostHooligan
      • Oct 2008
      I have a couple 260's at home that i can take a look at later on tonight or later this week and I will let you know what all is in mine. They are built basically the exact same way as a 270 from what i have found. Topcat, if you have any suggestions of what all I can look for maybe I can help you out a little better at getting a good list.
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • Akhlz001
        by Akhlz001
        09-20-2025, 07:15 PM
      • master3112
        by master3112
        07-29-2025, 01:55 PM
        Dell Thunderbolt Firmware
        by SMDFlea
        Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
        Some models have a choice of 2 different firmwares, it depends on the dell SKU.
        The SKU is in brackets (****)
        EDIT: NVM65...
        01-26-2025, 06:22 AM
      • dell_sadness
        Dell Latitude 3440 - Service tag ending in 0001 - Locked!
        by dell_sadness
        BIOS password locked Dell Latitude 3440 (Service tag B4HNJX3)
        Have extracted the BIN and want to know how to rebuild a clean BIOS
        I have come across the 8F8C patcher but not sure if that would work in my case as the service tag ends in 0001.
        I tried it and although the log states it patched several mentions of 8F8C in the BIN, I haven't flashed it yet in case such a patch wouldn't work.
        Have also tried to extract a clean BIN file from Dell's .exe BIOS updates using 'Dell PFS Extractor', but not confidently; Ended up with a 25MB file instead of the same 32MB...
        11-12-2025, 02:54 PM
