Odd issue with this
Rec'd board dead - was recap city
Most of the caps required replacement
Anyway, recapped these with Pana FM
Got some memory from eBay
2 of Crucial 512MB PC133 ECC Unbuffered
Using MemTest86 v3.3 to test the RAM
1st stick inserted DIMM slot 1 - Ran Test 5 and 8 for 20 iterations
Took some time - but tested ok
2nd stick inserted DIMM slot 1 - Ran Test 5 and 8 for 20 iterations
Tests ok
Inserted both DIMMs in slot 1 and slot 2
Test 5 fails - get bad memory address recurrently
I suspect this may be more of a problem with the mobo as opposed
to memory.
Thinks I'll re-check the traces and cap ESR on the DC-DC regulator
for the RAM
Any suggestions?
Tests ok
to memory.
for the RAM
Any suggestions?
