ABit KG7 is the Walking Dead
  • bgavin
    • Jan 2007
    • 1355
    This recap was interesting. Everything went smoothly, and it runs Memest86 with no more than the usual errors present in this board.
    The interesting thing is, the board is still junk. It was a tough install with XP Pro/SP2, and Quickbooks 2007 was a nightmare. The board is inherently unstable under XP.
    I suppose it could be a CPU, but I doubt it. Haven't done the legwork yet... have to pull it back out of the customer machine and swap in another AMD-761 board.
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: ABit KG7 is the Walking Dead
    Did you clear the CMOS after the caps replacement and re-do all the settings?
    Mann-Made Global Warming.
    - Dr Seuss
    • bgavin
      • Jan 2007
      • 1355
      Ya know... that is a real good idea.
      Some years back, I wrote a CMOS wiper that ripples zeros through all NVS ram. I will run that and force a reload just to see what happens.
      I'm more concerned that I have a cold flow on one of the new caps.
      As of this writing, I'm just testing another KG7 that I did a partial recap on. I did all the 3300 and 1500uF, and the 1000s around the memory and processor. I left the others alone. The board had all Nichicon HM and was acting finicky for the client.
      What sucks is, the recap board is far worse for the client than the old board. He is a good friend, but it still sucks. I'll do the CMOS thing first. Thanks for the reminder.
      • bgavin
        • Jan 2007
        • 1355
        A big thanks to PCBonez for reminding this old tech to not forget the basics. I wiped the CMOS with a utility that I wrote to ripple zeros through NVS.
        This forced a CMOS checksum error, and I reloaded the optimized defaults. I customize all my BIOS files for my clients, and the KG7 is no exception. The only serious changes I make to KG7 is changing the Slew Rate from Auto to 7 (Fastest). I found this tip for KG7 years ago, and it has never caused me any problems.
        I have three recapped KG7 in stock, and they all fail Memtest86+ Test #5 in exactly the same manner. I found a tip somewhere about the later BIOS versions cause this error. The machines perform flawlessly, so this is strictly a diagnostic bug.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Congrats!
          Your welcome.
          - Dr Seuss
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • k370
            Yoga3 Pro-1370 Board NM-A321 DEAD no power at all
            by k370
            I have a NM-A321 board that is dead, with no power at all.
            When I received the laptop, the +5VPMIC line was shorted. Removing the PU3 (ISL95905) solved the short, so I ordered and replaced the ISL.
            With the new ISL, the short is gone, but still no voltages at all. I measured the following rails:
            • +3VALW
            • +5VAUX
            • 1.2VSUS_PWRGD
            • 3VALW_PGD
            • 1.05VAUX_PWRGD
            Additionally, the ISL95906 (PU3) is not getting any voltage on the VIN rail.
            The only place on the board where I find any voltage is on the first MOSFETs, specifically:...
            09-23-2024, 11:57 AM
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
          • corrize
            Nikon D5 – dead, power board issue ?
            by corrize
            Hello, the DSLR has heavyly fallen. It is dead : no sign of life and display nothing.
            When it worked, it always displayed a card present state on LCD display, even when the battery is empty it display a empty battery symbol.
            I found a dead fuse, I replaced it and a mosfet burnt, I changed it and another fuse burned. Nothing burned after. And I can't find any short circuit anywhere, it's weird.
            Now, I try to understand how it works.
            There is two boards (the little one on pictures has no component) : the first is a « power board » : managing...
            04-03-2023, 09:13 AM
          • Asraf Atb
            Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
            by Asraf Atb
            Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
            Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
            I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
            01-27-2025, 05:02 PM
