Asrock 775V88+ Mobo
  • JEWilson
    • Sep 2007
    • 369
    • Scotland, United Kingdom
    Asrock 775V88+ Mobo
    Rec's this in unknown condition.
    Physical inspection finds underside has a few scratches - cannot find any
    traces s/c.
    Tried power up with a post card and AGP graphics adapter installed
    with suitable RAM. Result - NO POST.
    Everything appears ok voltage wise but it cannot load the BIOS.
    When mobo switched on, all voltage readings on the POST Card
    appear ok and the system will do a CPU reset.
    I checked the BIOS and find the correct version with my programmer.
    So... turning, to look at the caps on the mobo
    This board has;
    4 of 16.0V 1200 uF NCC KZE - published ESR is 0.022, readings 0.03-0.04Z
    6 of 6.3V 3300 uF NCC KZG - published ESR is 0.012, readings 0.04-0.06Z
    22 of 6.3V 1000 uF OST RLP - published ESR is 0.078, readings 0.08-0.12Z
    4 of 16.0V 100 uF Teapo SS - published ESR is dunno
    I cannot find the ESR for the Teapo SS but did find readings with my ESR
    meter varied from 0.22, 0.41, 0.59 and 0.56. Are these normal?
    I don't think the KZE and KZG are problems - what do you think?
  • gonzo0815
    • Feb 2006
    • 1600
    Re: Asrock 775V88+ Mobo
    Try a CMOS clear first, by removing battery, any power plugs and shorting CMOS clear Jumper.
    I have had some Asrock boards which needed this procedure to successfully boot.
    • JEWilson
      • Sep 2007
      • 369
      Finally got round to some further testing with this;
      As you suggested, I followed the instructions to reset the BIOS.
      Result - still no POST.
      Next, I reseated the BIOS IC (it is socketed) as, strange as it seems,
      I have had problems with this before.
      I have tried two different PSUs - these were;
      Q-Tec 550W Dual Gold Fan (premium recapped) and FSP (Fortron/Source) FSP350-60MD 350W
      I have tried two different types of RAM - these were;
      Elixir PC3200 512MB DIMM in single channel and Corsair XMS PC3200 512MB in single and dual channel (have 2 of)
      I have tried two different graphics adapters - these were
      XperVision GeForce FX5700 LE AGP 8x 256MB and Jace Tech J2225 (a GeForce FX5200) AGP 8x 128MB
      The problem persists - any further suggestions?
      • Harvey
        • Apr 2007
        • 264
        Is the CPU getting warm?
        • JEWilson
          • Sep 2007
          • 369
          CPU is known good
          Difficult to tell if the CPU is getting warm with the Intel s775 HSF in the way.
          I don't have a thermacouple to test CPU temp for sure.
          The POST card does report a CPU reset as part of the boot process.
          After that, POST read out sits at 00 00
          As the mobo does have a 4 pin header for a speaker/buzzer - I think,
          next, I will mount a speaker/buzzer to determine if I am getting a
          beep code alarm for RAM or the like. If I can determine this to be the
          case, then as the RAM is good, it may be a problem with the DC-DC
          block for RAM - this might be bad caps and/or regulator related.
          Q - During boot, after the CPU reset, the CPU should read address
          FFFF:0000 and execute the assembler jump to read and uncompress
          the BIOS image and load it into RAM. Of course, it RAM cannot be
          read, would this indicate the failure to load BIOS
          Any help - appreciated
          • JEWilson
            • Sep 2007
            • 369
            I constructed an audio lead with a speaker to attach to this mobo.
            I get no beep codes at all.
            The system simply sits and does nothing after a CPU reset,
            similarly so when a reset from the front panel is processed.
            FWIW - the CPU and n/bridge HSFs are becoming marginally
            less cold than at power on as best as I can tell from simply
            touching these.
            I am going to try a different bios chip (if I can find one).
            Perhaps the BIOS IC in situ is not working albeit I have
            successfully erased and programmed this device before.
            Any other suggestions?
            • starfury1
              • May 2006
              • 1256
              well no idea on that MB as to a likely cause.
              I guess computers now are the same as old, basic function wise
              Id check the VRM if you haven't already
              voltage rails and osc (clock)
              If there are those tiny xtals used on the MB I have known them to fail
              but on MB's, how often... no idea
              (or even if they still use them, maybe its contained in a clock generating chip)
              I'd give the MB a good visual too with a loupe or good mag glass, looking for possible dry joints.
              there are from memory small fuses that may be used on MB's so maybe one of them has popped
              maybe its just at the "write it off" stage considering the time you may have to spent on it.
              As I've said before grab some chip numbers and see if you can get a PDF this may help in trouble shooting.
              BGA solder joints have been known to fail so maybe apply a bit of pressure here and there to see if it is a bad joint.
              unfortunately not an answer for you , just some things to try or look at.
              Cheers and good luck
              You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
              • JEWilson
                • Sep 2007
                • 369
                I may have resolved this issue.
                Will report back once established fix has worked.
                First, the bios image (v1.3) as came with the board had
                a number of uCode patches. One of these i.e.
                CPUID 0F43h, Revision 0x04 11/01/2004 does not appear to exist.
                In fact, the correct patch should be;
                CPUID 0F43h, Revision 0x05 21/04/2005
                This is why (I believe) the PIV 650 Prescott was not working.
                No uCode existed to support the CPU.
                The system would always reset and do nothing.
                Of course, Asrock supplied later BIOSes with a number of
                uCode patches but they insist these are to be applied with the
                supplied flash utils.
                Now, I did try flashing with later BIOSes but of course was not
                aware of the uCode issue with the v1.3 BIOS and using a
                Willem, only flashed the image not the supplied uCode patches.
                I have used MMTool 3.19 for Windows to patch the correct uCode for the v1.3 BIOS
                and removed the incorrect entry.
                This has been applied ok but remains to be tested with a CPU
                and memory.
                MMTool 3.19 for Windows reported prior to patch update;
                CPUID 0F43h, Revision 0x04 11/01/2004 - incorrect
                CPUID 0F33h, Revision 0x0b 05/12/2004 - correct
                CPUID 0F34h, Revision 0x13 30/07/2004 - correct
                CPUID 0F41h, Revision 0x09 02/08/2004 - correct
                AMIBCP v3.13 for Windows reported;
                The last two as with MMTool were not reported
                Also v3.13 for Windows reported as;
                ID String 1 - 62-130-0000010-00101111-042505-VIA
                But this does not make sense. I know of no manufacturer
                as above.
                Any insight from forum members?
                • zandrax
                  Hit and miss
                  • Dec 2007
                  • 1157
                  • Italy
                  Strange: the flasher should copy almost everything, uCode updates included, except the boot block.
                  Try using Uniflash: maybe it works on your board.
                  Zandrax
                  Have an happy life.
                  • JEWilson
                    • Sep 2007
                    • 369
                    Well...
                    I flashed the original BIOS (v1.3) as came with the mobo
                    with the correct uCode patch but the mobo is still no go.
                    The mobo certainly appears to have all the voltages
                    stable and does a CPU reset but does not get to the stage
                    where it will load the BIOS.
                    My port 80 POST card reports this to be so.
                    I did have a problem with my willem programmer writing
                    the updated BIOS to the plcc device. This is odd.
                    It did work after I retried the flash.
                    I have done as above basic testing of cap ESR and test
                    for o/c and s/c on the ATX power connectors. These
                    are all ok.
                    Now, as a result, I'm beginning to suspect the BIOS device.
                    The heatsinked northbridge get slightly hot.
                    I believe that is ok, but....
                    I will need to get meter readings of all of the relevant parts
                    of the mobo. This will be;
                    VRM for the CPU - I/P and O/P sides
                    DC-DC block for memory.
                    Supply voltages to the BIOS IC etc.
                    • zandrax
                      Hit and miss
                      • Dec 2007
                      • 1157
                      • Italy
                      Via northbridges aren't hot: the heatsink may be warm and it's normal, but being so hot you can't touch it isn't normal. Let's hope it isn't a shorted chip.
                      Keep us updated.
                      Zandrax
                      Have an happy life.
                      • JEWilson
                        • Sep 2007
                        • 369
                        Yep - correct
                        It is only warm to touch - it does not get extremely hot,
                        neither does the southbridge.
                        I have a couple of mobos for repair, which, at boot, gets the
                        southbridge very hot - too hot to touch and I cool them
                        with freezer spray. Clearly there is a short on these boards
                        as PS-ON is not set and the PSU stays off.
                        You can of course force the PSU on which is how I identified
                        the southbridge matter with those mobos.
                        I suspect there is a short or shorts, possible to the regulation of these
                        devices but that's another story and I never let those get to
                        a thermal runaway condition - promptly sever power to the boards.
                        • JEWilson
                          • Sep 2007
                          • 369
                          I've got back to testing this mobo.
                          First, I replaced the OST RLPs with Panasonic FM and FJs.
                          Several of the OST reported higher than spec. ESR when
                          pulled from the mobo (out of cct.).
                          Next, I require some clarification on a clock issue.
                          I tested the 32.768kHz xtal on this board with the freq.
                          test range on my mmeter. This item appears bad as
                          it does not appear to be within spec.
                          Conclusion - replace the xtal (part has been ordered).
                          Q - would this impact on the BIOS failing to be read?
                          I understand the VIA VT8237R s/bridge uses this for
                          the RTC. If the clock source is in error, would this
                          account for the symptom?
                          I use a PCI POST Diag Card and this reports all voltages
                          appear ok as well as the ISA OSC frame being present
                          as well as the clk LED being lit. By clk, this must obviously refer
                          to the PCI clk (33 MHz).
                          If this is correct, as the clock synth generates the
                          CPU, AGP and PCI clks - it may be these are ok.
                          The synth chip has, as is common, a 14.318MHz xtal source.
                          As the POST/Diag card reports a CPU reset but that
                          is as far as the boot process gets, it is unclear
                          if the LPC interface to the BIOS has a strobe.
                          I can't immediately determine if the RTC source is
                          symptomatic of the boot issue.
                          Perhaps a number of the members can refresh my memory
                          here.
                          Unfortunately, my mmeter only has a range up to 200kHz
                          Hence, I cannot be sure about this.
                          The only xtal is the 25MHz LAN PHY xtal.
                          Again, I cannot test this with my mmeter
                          As an aside, can someone recommend a standard mmeter
                          with a freq. measure up to 20MHz and above?
                          • gonzo0815
                            • Feb 2006
                            • 1600
                            Regarding your flash problem with the willem, AFAIk asrock does use some flash protection bits. The only program to handle those is the Asrock flash proggy.
                            i am not sure, if your particular board is protected this way too.
                            • JEWilson
                              • Sep 2007
                              • 369
                              Y - I thought that may be an issue
                              I have replaced the RTC xtal.
                              I also pulled the VRM caps to test these out of cct. as well
                              as being able to test the MOSFETs.
                              These are all good.
                              Further, I tested the temps on both the s and n/bridges
                              These both raise about 8 deg C after more than several
                              minutes after power on. This might confirm these are both ok.
                              The problem you indicate whilst being plausible presents me
                              with a problem. If I have a bad BIOS image whether via using
                              the Willem (or not), as I cannot get the system to boot,
                              the only way to address this would be to get a copy of
                              a known good BIOS for this system mobo in a plcc package.
                              Hmm.... where could I get this?
                              Thx
                              • lagacy
                                • Sep 2008
                                • 3
                                Coud you try to locate a SMD transistor positioned nearby the power-on/reset pins. I used to detect a broken B pole. I replace it with a NPN 600ma general purpose transistor and it is fixed. Another Asrock 845 got the same symtom but this one has a defective TL431 located near the south bridge.
                                A "special" characteristic of Asrock mobo is that it does not work with "aging" IDE cable while other mobos were not affected.
                                Hope that would help
                                • JEWilson
                                  • Sep 2007
                                  • 369
                                  I have not got round to testing the SOT-23 SMT devices.
                                  There are a number of these on this system board.
                                  I will do so now as well as replacing the TL431 discrete regulator.
                                  The TL431 is present on the Asrock 77588+ mobo near the s/bridge.
                                  Are you referring to the transistor as failed on an Asrock 77588+ mobo,
                                  or are you referring to another Asrock system board?
                                  Thanks for the tip.
                                  • lagacy
                                    • Sep 2008
                                    • 3
                                    Thanks for the tip.
                                    Sorry. I don't remember the model No because I dit that last year.
                                    • Ibod
                                      Corsair cx600 psu & ASRock B450Pro4 mobo wont start
                                      by Ibod
                                      HI I have a PC using a Corsair cx600 psu & ASRock B450 Pro4 mother board that won't power on after a shutdown (replaced a dead drive in a raid array) Not the boot drive.
                                      With most things unplugged, including the 24 pin ATX connector, but not the ATX12v to cpu, I have +5.01V on the +5vsb pin 9 from the PSU. When I plug the 24 pin back in to the mobo, the +5vsb fluctuates between 1.1v & 1.9v.
                                      Not sure where to go from here ?
                                      Is the PSU at fault or is the mobo causing the problem
                                      Look forward to any help :-)
                                      If I plug the 24...
                                      02-08-2023, 11:00 AM
                                    • stavi
                                      Asrock 775V88+ mosfet identify
                                      by stavi
                                      I want to identify a mosfet. Unfortunately, I couldn't find the asrock 775v88+ schematic.
                                      Does anyone know what this mosfet could be? It is between the agp port and the 1st pci slot. Q14 is his number.
                                      Thanks for the help...
                                      09-08-2022, 07:49 AM
                                    • Exim
                                      ASRock N100M, no picture no boot, but semi-alive
                                      by Exim
                                      Hi guys,
                                      I managed to semi-kill an ASRock N100M board after updating Bios from 1.10 to 2.01. It's a zombie now, dead, but not dead.
                                      ASRock N100M special features:
                                      - CPU soldered to board, small Intel 12th gen
                                      - iGPU
                                      - four POST LEDs
                                      Problem after updating Bios to 2.01 using the in-Bios update tool: no picture, no boot.
                                      I am not sure anymore if it booted at least once successfully after updating the bios to 2.01, maybe not, I can't remember. I think it did not.
                                      Symptoms:
                                      - no picture/signal on any of the display connectors,...
                                      04-01-2025, 02:36 PM
                                    • ChaosLegionnaire
                                      by ChaosLegionnaire
                                      09-13-2022, 09:02 AM
                                    • nolaryie
                                      BIOS .bin file for ASRock B450M Steel Legend
                                      by nolaryie
                                      Hi, I’m looking for a clean, working BIOS .bin dump (16MB) for the ASRock B450M Steel Legend motherboard.
                                      I’ve already tried flashing the official ASRock ROM file via CH341A, but it won’t post — I believe the capsule format is incompatible.
                                      Any BIOS version that supports Ryzen 5 2600 is fine (e.g., P2.30–P3.60).
                                      If anyone has a working board and can dump the BIOS using CH341A or flashrom, I would really appreciate your help.
                                      Thank you!
                                      08-06-2025, 12:01 PM
