Epox 8KRA2+ blown GSC
  • Super Nade
    • Jun 2006
    • 294
    Talk about putting crap on a motherboard... Almost all GSC 1500uF and 1000uF cans are leaking.
    Caps are:
    Sanyo 3300uF 6.3V (will not be replaced)
    Teapo 1500uF 6.3V
    GSC 1000uF, 1500uF 6.3V
    The replacement is going to be:
    Q6700 @ 3.6 GHz
    Zippy GSM-6600P
    Curcial Ballistix PC6400 (4 x 1Gb) Micron D9GMH
    Abit IP35Pro
    ATi HD4870
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Epox 8KRA2+ blown GSC
    too bad you cannot use those on anything but vcore and vdimm.
    did you get any of the 820@2.5 from that seller?
    they would be best for vcore.
    i have used some 560@4 for vdimm.
    some simple ohmeter testing and marking is in order.
    • Super Nade
      • Jun 2006
      • 294
      Yea..true. The package was all of the same. I was hoping for an assortment, but since the deal was pretty good, I just went ahead and took the whole bloody lot.
      Q6700 @ 3.6 GHz
      Zippy GSM-6600P
      Abit IP35Pro
      ATi HD4870
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        did you wind up with a 10,000 lot?
        btw if you need some 820@2.5 holler
        i have fujitsu and ncc.
        • Super Nade
          • Jun 2006
          • 294
          That would be sweet mate. I'll definitely take you up on the offer. I did end up with the 10k lot. The seller also had huge 4k-10k lots of Rubycon MBZ. He said it was unopened, but my wallet could only go so far.
          Here is a slideshow of pics of the MB. As a first test I removed the blown caps and replaced them with the OS-CONs or UCC LXZ. The board POST's, so now I can move on with the rest of it.
          http://img410.*************/slidesho...12138350s.smil
          Q6700 @ 3.6 GHz
          Zippy GSM-6600P
          Abit IP35Pro
          ATi HD4870
          • Super Nade
            • Jun 2006
            • 294
            In case anybody is interested, I actually calculated stuff to see if I was in spec according to THIS (pdf) document from AMD.
            Q6700 @ 3.6 GHz
            Zippy GSM-6600P
            Abit IP35Pro
            ATi HD4870
            • Super Nade
              • Jun 2006
              • 294
              Board now runs memtest after replacing those crapacitors. Tomorrow, I'll finsih the recapping job.
              http://img508.*************/slidesho...217876kd8.smil
              Q6700 @ 3.6 GHz
              Zippy GSM-6600P
              Abit IP35Pro
              ATi HD4870
              • linuxguru
                • Apr 2005
                • 1564
                Are those Sanyos OSCONs or polymers? If it's the former, have the purple sleeves been replaced by bare metal/lacquer?
                • Super Nade
                  • Jun 2006
                  • 294
                  They are Sanyo OS-CONs. Sanyo no longer use sleeves.
                  Q6700 @ 3.6 GHz
                  Zippy GSM-6600P
                  Abit IP35Pro
                  ATi HD4870
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    all mfrs are moving away from the shrinkwrap sleeves.
                    btw oscon is polymer too.
                    • Super Nade
                      • Jun 2006
                      • 294
                      Yep, conductive polymer. Their audio line uses some kind of organic material. I don't know too much about it. Maybe kc8adu can shed more light on it
                      Q6700 @ 3.6 GHz
                      Zippy GSM-6600P
                      Abit IP35Pro
                      ATi HD4870
                      • Super Nade
                        • Jun 2006
                        • 294
                        Job's done! Now it is going to run memtest for 2 days straight before I ship it back to the owner.
                        http://img516.*************/slidesho...30349558g.smil
                        Q6700 @ 3.6 GHz
                        Zippy GSM-6600P
                        Abit IP35Pro
                        ATi HD4870
                        • Per Hansson
                          • Jul 2005
                          • 5895
                          • Sweden
                          Nice job!
                          What are the rest of the (blue) caps you replaced?
                          • Super Nade
                            • Jun 2006
                            • 294
                            Blue = Chemicon LXZ.
                            Brown = Chemicon KY.
                            19 hours and not a single memtest error.
                            Q6700 @ 3.6 GHz
                            Zippy GSM-6600P
                            Abit IP35Pro
                            ATi HD4870
                            • cmlewis89
                              LG 47LB5DF blown power supply board
                              by cmlewis89
                              Hi folks,
                              I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                              09-03-2024, 07:50 PM
                            • drscoot
                              HP X360 convertible battery blown fuse error, not charging
                              by drscoot
                              HP Modelnumber: 14-dh0061nb​
                              This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                              The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                              I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                              And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                              All these 3 batteries are charging...
                              12-15-2023, 05:54 AM
                            • Kingpin!
                              3COM OfficeConnect Gigabit Switch 16
                              by Kingpin!
                              3COM OfficeConnect Gigabit Switch 16 (3C1671600)
                              The switch has served me for 10+ years (was new when I bought it). It's a nice switch with connections on the back which makes for quite a clean desk. Reason for taking it apart was that the cooling fan was noisy so I expected it to be dirty/dusty inside and the need to order a new fan. What I found was that it was very dirty/dusty and some electrolytic capacitors which needs attention. There are 3 capacitors which needs to be replaced but the ESR on some of the other ones might be bad as well so I think I'll replace them all. Original...
                              09-17-2023, 04:58 AM
                            • swerg
                              Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
                              by swerg
                              Hey everyone,
                              I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
                              I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
                              I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components...
                              06-06-2024, 03:39 PM
                            • ohren
                              What problems could this blown cap cause in a Marantz SR5400?
                              by ohren
                              I'm looking at a vented C513 in a Marantz SR5400 (photo included), in the FR section on page 24 in the service manual (https://audiocircuit.dk/downloads/ma...400-avr-sm.pdf).
                              R533 right below it in the photo is charred, but measures the correct value.
                              1. I'm not familiar with amplifier circuits (at all — don't know the difference between classes, etc.) so I was wondering what problems would manifest from a supposedly non-operational C513? I didn't hear anything odd when testing the output channel with a speaker. Is there a simple test that can be done...
                              10-21-2025, 09:02 AM
