Jetway PM9MS Bulging Caps
  • Doramius
    • Nov 2007
    • 25
    I was given this MB to check out and noticed the Caps right away. Took these snapshots, and you can see the deformation of the top just bulging on specific Caps.
    Not sure which replacements to use, but I'd like to replace all of the larger Caps at the same time (regardless of good or bad). Not only is it usually the suggested method, but I don't feel like having the others go out on the board too.
    The bad Caps are 3300uF 4V. The 2200uF 10V Caps aren't bad but I haven't seen anything as to whether they are good or not. Probably would be a good idea to replace them, for the previously stated reason.
  • Big Pope
    Approved Vendor
    • Dec 2005
    • 426
    Re: Jetway PM9MS Bulging Caps
    These caps are SACON or EVERCON, all are Jetway's lover brands.
    My SAMXON Capacitors Database HERE!!
    X-CON is a new brand for SAMXON's Polymer Capacitors.
    • gastorgrab
      • May 2007
      • 320
      Aaaaahhhhhh, i knew there was something funny about the shape of those vents.
      https://www.badcaps.net/forum/showpo...82&postcount=3
      • linuxguru
        • Apr 2005
        • 1564
        What are those in the brown sleeve in the foreground? Samyoung NXG (?) - I haven't ever seen those before.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          looks like the 470@16 near the amr and agp are just starting to go.
          i would recap the whole thing.
          • gastorgrab
            • May 2007
            • 320
            Before this goes any further i should say that mine was not the original post.
            The picture in my post is only used as an example, showing the brand,to the original post'r. The picture is from another thread here at BadCaps.net.
            • re-atari
              Denon AVR-X2000 mainboard caps bulging
              by re-atari
              I have been using a Denon AVR-X2000 receiver in my living room for several years now, works perfectly, am very pleased with it. Recently I acquired another one, advertised as defective with flashing red led a few seconds after switching on. Picked it up to try repair and use in hobby room. After switching on, the on/off indicator led indeed initially flashes green for about 2 seconds, during which the display is visible, and then starts flashing red (at 2Hz) with a switched off display.
              I'm afraid the service manual is too large to upload here (55Mb), it can be found at https:/...
              09-23-2020, 10:37 AM
            • eryjus
              by eryjus
              05-10-2023, 11:21 AM
            • Paxman_Swede
              by Paxman_Swede
              Hello!
              01-14-2025, 09:51 AM
            • captain150
              by captain150
              03-16-2025, 07:34 PM
            • Foetuss
              Gigabyte GA-6OXT :: caps question
              by Foetuss
              Good evening
              I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
              Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
              But I was also suprised about the bigger boys, which are 330µF 25V.
              Could it be they used 25V caps because they were cheaper / available at that time?...
              02-11-2025, 12:22 PM
