Tale of two GA-K8VM800M
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Both Rev.1 and example of mass production variation
    First has MBZs for VRM input and KZGs for output - one KZG blown, shown in pic
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Re: Tale of two GA-K8VM800M
    Second has KZGs for input and MBZs for output - all look OK, pic
    • pfrcom
      Oldbie
      • Jun 2006
      • 1230
      Originally in filthy condition - cleaned in water with Simple Green, then dried outdoors in Australian Summer sun
      Afterwards neither would start - sprayed with Isopropyl alcohol and left to dry outdoors again
      Then they started, and so did my frustration
      With the first, I replaced KZGs with recycled HMs and thin MBZs - deprecated practice, but board's worth very little
      • pfrcom
        Oldbie
        • Jun 2006
        • 1230
        The first did an install of Windows XP with one issue - Code 10 for Sound - it's Realtek ALC655, using a well proven driver
        In Details it has SUBSYS_00000000 - compared to SUBSYS_A0021458 for one without issue
        No issues at all with second - no exclamations in Device Manager, including Realtek AC97 - but no sound either
        To verify, I swapped in my Rev.2 K8VM800M - and after XP adjusted for its differences, there was sound
        I've tried different drivers, and older BIOSes, all to no avail
        Along the way, its Realtek AC97 device vanished - don't even see Sound allocated an IRQ, in list shown by BIOS during startup
        I've even tried replacing original three 100uf 10v Teapo near ALC655 chip, with 100uf 16v KMA recycled from a defunct Intel board
        Shown in this pic - note default jumpers on F_AUDIO, been caught before by that gotcha for no sound
        • pfrcom
          Oldbie
          • Jun 2006
          • 1230
          Amount of time I've spent on these, I should have left them in the computers left out for rubbish collection
          • pfrcom
            Oldbie
            • Jun 2006
            • 1230
            With more searching I found a driver for the first board, accepted by XP for Realtek AC97
            But still no sound produced
            After these, plus an Asus A8V Deluxe that also produces no sound even though driver shows no issues, I reckon on-board Realtek sound is just plain fragile
              master hoarder
              • May 2008
              • 12170
              • Bulgaria
              That could be it. Or perhaps something specific with those chips, their drivers, and XP. Would be interesting to try another OS. Maybe Windows 7?
              An HP DC7700 motherboard did something similar to me recently where the AC97 just disappeared randomly from Device Manager and no more sound after that. But that was with a SoundMax onboard audio, so I can't imagine this to be the same problem. However, I will note that both the HP website and Windows Update had some specific patch for that that fixed my problem.
              So that's why I am suggesting a different (and possibly newer) OS - just for an experiment.
              • pfrcom
                Oldbie
                • Jun 2006
                • 1230
                Not optimistic, seeing second board no longer shows a sound device in the IRQ list produced by Award BIOS
                Speaking of which, it's F8, the latest for a Rev.1 board
                BTW, the first board also had sound issues when I booted from a Knoppix CD
                I'll try the second board with Windows 7, and post an update
                  • 30983
                  are you sure you dont need jumpers on the front-panel conector to route the sound to the jack sockets?
                  i have a few boards like that.
                    • 30983
                    just checked my similar K8ns-pro
                    if you have a 10pin front audio connector, you need to put a jumper across 5-6 and 9-10 to route the autput to the back.
                    • pfrcom
                      Oldbie
                      • Jun 2006
                      • 1230
                      Thanks, but in post #4
                        master hoarder
                        • May 2008
                        • 12170
                        • Bulgaria
                        True.
                        But you also miss out an opportunity to improve your troubleshooting skills, or learn something new perhaps.
                        Could be that too. It seems strange that the sound went out on both boards and no device in Dev. Manager. Certainly doesn't sound like an SB BGA issue, especially since those VIA chipsets likely don't get hot at all to cause that.
                        However, now I also recall having a computer with an Asus A8V-MX where the sound disappeared is a similar manner (I don't remember if the sound devices disappeared from Dev. Manager, but they probably did because I remember trying to reinstall the drivers several times). Long story short, I found that the problem was caused by a wrong driver for some other device I tried to install on the board. I don't remember how I spotted that, though. Also, that board had an ALC653 chip, which could be similar to what you have.
                        If that's not the issue, then I wonder if Gigabyte just did something wrong with the board design to cause that. Check AVDD (pins 25 and 38), DVDD (pins 1 and 9), and VRef (pin 27) voltages on the Realtec ALC655 chip on your board and make sure they are in spec.
                        That shouldn't make the audio disappear from Device Manager, even if he didn't have those jumpers.
                        • pfrcom
                          Oldbie
                          • Jun 2006
                          • 1230
                          First board does have Realtek AC97 in Device Manager - but produced no sound after I found a driver to satisfy it
                          Extreme example with those jumpers missing was an Intel D845GERG2 which wouldn't even power up
                          Bought it as faulty - pleased with the fix required
                            • 30983
                            ah yes, power.
                            the audio pre and output stages need seperate power.
                            get some pinouts and go digging.
                            it may be a bad inductor or regulator.
                            • pfrcom
                              Oldbie
                              • Jun 2006
                              • 1230
                              I did try an install of Windows7, from scratch, on the second board - not surprised that it ended up saying: No sound device installed
                              And to add insult to injury, the second board has now decided to lose CMOS settings when power is switched off - with a CR2032 measuring 3.06v on DMM
                              • mockingbird
                                • Dec 2008
                                • 5484
                                Maybe there's some water creeping beneath some BGA? What I always do when I clean PCBs with water is hold a gasolene funnel to the end of my shop vac hose (shop vac hose hooked on exhaust of course) and then blow the heck out of every crevice. You'll see droplets of water flying out at light speed. You've got to have a good powerful shopvac, like the ones construction people use with a powerful motor.
                                • pfrcom
                                  Oldbie
                                  • Jun 2006
                                  • 1230
                                  I wondered that, especially the second board with its escalating failures
                                  So, prior to the Windows7 test, I fired up my air compressor and tried blowing out its various nooks & crannies, albeit with air pressure fairly low
                                  This thing's giving me the sh*ts so much, I might repeat with the air pressure dialed up
                                  • pfrcom
                                    Oldbie
                                    • Jun 2006
                                    • 1230
                                    Mockingbird is on the money
                                    Before having another go with compressed air turned all the way up to Eleven, I decided to remove the northbridge heatsink
                                    To find a smear of water down one side of the chip - right side in the attached pic
                                    So I sprayed it all over again with Isopropyl alcohol, then finished off with compressed air, a bit higher than previous but nowhere near maximum
                                    Afterwards, the problem of losing CMOS settings was fixed
                                    Unfortunately on-board sound hasn't come back - maybe I'll have a look at voltages on the ALC655 later, although fineness of its pins is a bit off-putting
                                    So lesson learned - static air drying is insufficient after a bath - need moving air as per https://www.badcaps.net/forum/showth...hlight=smokers
                                      • 30983
                                      actually, you should have removed all heatsinks first.
                                      because otherwise you could have washed away any paste without knowing.
                                      • pfrcom
                                        Oldbie
                                        • Jun 2006
                                        • 1230
                                        No chance of that happening, as it turned out
                                        Not an atom of heat sink compound on the northbridge originally - has AS5 now
                                        Or maybe I did wash it away in the first place
