Tale of two GA-K8VM800M
Re: Tale of two GA-K8VM800M
on your 3rd post, you don't state if either board was working before cleaning them; and if either of them was working, what problems, if any, were present.
i made a similar mistake... whereas if i powered up the board and watched how it ran prior to recapping (or cleaning), there would have being the option to compare before and after states.Last edited by socketa; 02-23-2015, 03:32 PM.Comment
No extensive testing because of the filthy condition they were inbetter to keep quiet and be thought a fool, than to open your mouth and remove all doubtComment
by hellDS-7108HGHI-F1/N pcb 101223798 80257_p rev1.5
I am looking for DS-7108HGHI-F1/N pcb 101223798 80257_p rev1.5 rom. Can you share the one you have? It appears on several Egyptian sites. Can anyone help? The device turns off and on again.... -
by musdakHello help i need dump HIKVISION DS-7204HQHI-F1/N DS-80260_P REV1.2...
by şahan34please help Hp 15-bs153nt DKL50/CSL52 LA-F761P rev1.0 after 5min FREEZİNG cpu coil It overheats a lot. CPU VOLTAGE 1.81 Photo
by kadirinan34Hello friends, I need the BIOS file of this device, thank you.
Gigabyte A520M-K Rev1.0...-
Processor with markings X220H171 SRK08
LA-L246P
REV1:0
Hello, after unsuccessful cleaning, the laptop does not respond to the switch
Resistance to ground on the coils
PLB01- 5,220MΩ
PLM01-112Ω
PL501-46KΩ
PLZ01-8Ω
PLZ02-8Ω
PLG2-36Ω
PL181-2KΩ
PL180-2KΩ
PL301-17KΩ
On the layout
MCROCHIP
MEC1515-NB I found a low resistance of 7Ω, +3VALV_EC power supply, after desoldering the MEC system, the resistance increased to 20KΩ, and the protective foil was melted on this system.
I found out that... - Loading...
