Gigabyte GA-K8VM800M recap worked but now dead?
  • socketa
    replied
    Re: Gigabyte GA-K8VM800M recap worked but now dead?
    looks like i'm dreaming to think that this can be done with a heatgun, as it makes sense that heat needs to be applied from the top side, not the back side.
  • diif
    replied
    I'm sure there is a thread on here, where someone replaced a socket. IIRC they used their IR station to prevent the plastic melting and removed it in one piece.
  • ben7
    replied
    Originally posted by socketa
    Up until now, was thinking about desoldering each of the contacts, removing them with micro tweezers, and then soldering in 'new' ones from another socket.
    Would that be possible? Has it being done before?
    Hm, you do realize, that sounds VERY tedious!
    Anyway, how to go about completely replacing it with this replacement socket?
    Break out the heat gun,
    heat up the back of the board and check temperature with a thermocouple,
    pull it off,
    clean the area of all the old solder using soldering iron, flux and braid.
    heat it back up again and then pop in the new one?
    Sounds like a plan to me.
    Just be aware that removing the whole socket at once might be difficult. Every pin would have to be loose (solder melted) in order to remove the socket ... and that thing has a lot of pins!
    You might also be able to use a desoldering iron to desolder each pin. That way you have less of a chance of damaging the PCB by heating it up too much.
    -Ben
  • socketa
    replied
    Have had the board sitting beside the desk for a while.
    It's got about 7 damaged contacts, and i just got onto ebay and noticed that the socket is for sale, then checked back here, and saw the replies.
    Thankyou
    Turning the motherboard over, i see that the opposite side of the socket is soldered where the CPU contacts are, so this socket looks like a through-hole type, with legs.
    pull it off,
    If the board has lead solder, wouldn't the replacement socket also be presoldered with similar solder?
    Or, does all of the old solder have to be removed first?
  • diif
    replied
    Depending on what kit you have a new socket isn't much. http://www.aliexpress.com/item/Origi...854569169.html
  • TechGeek
    replied
    Do you still have the board?
  • socketa
    replied
    As previously stated, the original caps were HM, and that is what they were replaced with. I don't think the board would now need HZ.
    And retried tried several RAM sticks (both of which were working fine on the board)
    Anyway, after straightening up the socket contacts as best as i could, still get the same response.
    So i now regard the boad as scrap
    Next time i will start with checking that the board is working.
    That appears to be the moral of this story.
    Thanks for the interest.
  • ReeceyBurger123
    replied
    [QUOTE=Sparkey55;523692]Some of Gigabytes motherboards require much lower ESR values than HM series. Especially the VRM outputs. Also we do not know exactly what he replaced the original caps with. Real or fakes? Also some socket 754 boards a finicky about the DDR choices. A lot yet to be confirmed.[/QUOTE
  • Sparkey55
    replied
    Yep.
    Am also suspicious that there was some damage present before i brought the board, because as soon as i saw it had bloated caps, i thought it was better not to turn it on with them in.
    Then after replacing them, it didn't boot, took of the heatsink (with CPU attached) and stuck it back together with new paste, and it booted - which may have repositioned the CPU just enough to make a pin contact.
    It is like playing Russian roulette. I need to know if a mobo works befor a recap. If it dies, oh well.
  • socketa
    replied
    Yep.
  • Sparkey55
    replied
    Well got the top off, and only broke the back clip
    Prying it off in each of those slots with one side of tweezers and using a toothpick to hold open the gap while moving on to the next slot.
    I think there is a reasonable chance that this is why the mobo is not happy
    One of the cubicles near the front only has one contact and quite a few in the problem corner look reasonably disorganized.
    Now how to fix it?
    Is the lower right corner that is shown in the photo the corner that you said you had to push down for the cpu to seat all the way?
  • socketa
    replied
    Ok
    Tidied them up with a pin and magnifying glass,
    and they look a lot better now, except for about 4 that look like they only have one contact instead of two.
    Will get a microscope later in the week for a closer inspection
  • socketa
    replied
    Now how to fix it?
  • socketa
    replied
    I just practiced on an a dead socket A board
    On both sides there was a gap between the board and the top sliding cover,
    so used a screwdriver to pry it up, but it still cracked and i managed to snap off two tab hooks at the back of it.
    Now that it's off i see that i should have used the slots on the top to lever the sides outwards and unhook them
    Now on this 754 socket, i tried to lever the sides outwards with a small screwdriver in either of the 3 side slots, but it's not moving easily
    looks like i might need to make a 3-prongged 'screwdriver' to lever off the side in one movement?
    Anyone done this before?
  • Sparkey55
    replied
    Well that was easy, but didn't achieve much because i thought that there might be some fastners, under the black plastic pad, that i could remove to get the CPU socket off.
    How to i remove the sliding socket to access the CPU pin contacts?
    It should snap off if done carefully. Although we are now treading in uncharted waters. i have not done this type of disassembly before. Good luck and god speed.
  • socketa
    replied
    Well that was easy, but didn't achieve much, because i thought that there might be some fastners, under the black plastic pad, that could be removed to get the CPU socket off.
    How to i remove the white sliding socket pin-guide to access the CPU pin contacts?
  • Sparkey55
    replied
    In the famous words of Elvis - thankyou very much
    Might have to open an ebay account
    Ok
    Started with a pin that was too wide,
    so narrowed it down with a ginder
    After a few proddings thought a bit of stripped telephone house wire might be the right size, since the grinder didn't produde a uniform rezized pin
    the phone wire worked well
    Perhaps fishing line might be a better option
    On some holes the grip was questionable, and on a few of others it would not go down without some force
    So then i got the lamp and a magnifying glass and compared to the rest of the paired contacts in the socket holes while moving the lever. Quite a few look out of alignment, On one i can't see any metal although the wire doesn't want to go down that hole, and a couple of contacts were right next to each other, rather than the v-shape (i, may have caused that when i forced the socket in).
    After seperating them with the pin, the CPU still doesn't want to fall in to the socket.
    I can also recall that when i removed the original CPU, i saw a tiny piece of copper on the board near the CPU socket, but ignored it, especially since afther reinserting it, the compter booted OK.
    But am now thinking that it might have being one side of one of the socket contacts
    Looks like i'm going to have to remove the socket housing and straighten the contacts up, back to their v-shapes, and see what damage has being done.
    There is a black plastic pad on the reverse side of the board held in with two white plastic fastners on either side
    Here's thumbnails of both sides of the fastner - how do i remove that, and then remove the CPU socket cover?
    It looks like on the top of the fastner is a round plastic stake pin that pulls up then use needle nose pliers to squeeze the bottom spreaded tabs together and that should let you pull the retainer off.
  • socketa
    replied
    Ok
  • Sparkey55
    replied
    found this on eBay. Never used one myself so do not know if they work but cheap.
    http://www.ebay.com/itm/Desktop-CPU-...#ht_2829wt_842
  • selldoor
    replied
    Originally posted by Sparkey55
    Something else to try: Try inserting a metal pin into the cpu socket pin holes in the corner that gives resistance. Open socket latch, insert pin into hole, close latch, then pull slightly on pin to check for tightness. Do this one pin at a time. Be sure to use a pin the same diameter as the cpu pins.
    That is a great tip - I love it Thanks
    A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
    by momaka
    More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
    And a shot of the label:...
    01-26-2022, 03:26 AM
  • Prott
    Gigabyte GTX1080 - identifying a dead short on vmem
    by Prott
    Hey!
    I have a problem with Gigabyte Aorus 1080. The card seems fine (expected resistance on vcore, pex, 5v, 1.8v, 12v and reset) except for a dead short on vmem (FBVDD). It's interesting failure mode, cause usually (in my experience) when memory fails it still retains a few ohms - this one is literally a dead short.
    I removed the inductors and tried inject voltage (0.8 V at 6 A) which only seemed to warm up the cables to the card while the card itself didn't show any hotspots.
    Is there any way to narrow down the search for a short? I would prefer not to remove...
    07-04-2023, 06:29 AM
  • JimMc0
    Gigabyte GA-H61M-USB3-B3 dead short 3.3v rail to ground.
    by JimMc0
    Hi there,
    I discovered this forum through a youtuber who teaches electronic repair. I've been trying to troubleshoot my dad's old PC which is a Gigabyte GA-H61M-USB3-B3 and will not power on. I discovered a dead short on the 3.3v rail at the ATX connector so I used a bench power supply to feed 3.3v into the ATX connector and sunk about 400mA into the board (I hope that's not too much!). I used a FLIR camera to identify the problem area:
    The chip seems to be the following, an ITE IT8892E 1108-CXS which seems to be a PCI bridge?
    03-27-2024, 08:36 AM
  • DynaxSC
    GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
    by DynaxSC
    I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
    General test conditions:
    - Tested with Core i5 6500 and Core I7 6700K - no difference
    - Default BIOS settings, but tried also altering several memory setting - does not change anything
    What is wrong:
    With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
    When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
    03-21-2025, 06:23 PM
  • pkslowk
    Debug Card Error Code and Solution
    by pkslowk
    Sr. Motherboard Debug Error Code Solution
    1 Intel 845 E9 Bios Related Problem
    2 Intel 845 D4 CPU Socket Related problem
    3 Intel 845 37 Bios Related Problem
    4 Intel 845 7C Bios Related Problem
    5 Intel 945GCPE 34 Bios Related Problem
    6 Gigabyte 845 2 Ram Related Problem
    7 IBM Server A6 A7 Ram Mismatch Problem
    8 Asus 845 29 CPU Related Problem
    9 Lenovo I946 97 C-Mos Jumper related
    10 Gigabyte 845 A0 CPU Related Problem
    11 Asrock G31M-VS D7 Bios Related Problem
    12 Compaq 845 BD-70G B0 CPU Socket Related problem...
    01-28-2021, 12:51 PM
