ASUS PRIME B450 PLUS (rev 1.02) USB Overcurrent issue
  • ezenia
    • Jun 2020
    • 58
    • England
    So I bought a faulty ASUS PRIME B450 PLUS motherboard off eBay. They said it was water damaged and they cleaned it. The PC POSTs and displays a message that it's detected USB overcurrent and will shut off in 15 seconds. I verified this myself. So I did some checks at the ATX connector 1st to see if the resistance readings looked OK. I found the 3.3V rail measures just 179Ohms which seems way too low. It's been much higher on other AM4 boards I've worked on.
    So I did some Googling to see what the potential culprits are. It varies from bad protection diodes, bad ports or even the PCH. I went to the protection diodes (they are SOT23-6) and measured the resistances on the legs against GND. All looked OK, but one. One was reading close to the Ohms I was seeing on the 3.3V rail. I attached an image of the 2 readings on the chip:
    So I removed it to see if that changed anything. Unfortunately not, the resistance readings remain the same. It seems like only one port is affected. I checked the pins on the USB port at the back of the board, on 2 of the pins for one port, I get the same low ohm reading. On the other port, I don't see the same low ohm reading. The ports are USB 3.1 Gen 2. They're light blue.
    Before going further with this repair, I'd like to know if this issue is perhaps being caused by the PCH since the 3.3V rail is also reading low ohms. If it is the PCH, then there's not much I can do about that. If it's not the PCH, then I can continue to find where the issue is.
    Appreciate any help on this. It would've been nice if I had a boardview for this board, but couldn't find one (I've requested it in the appropriate section).
  • wisjg
    • Oct 2025
    • 4
    • China
    U74LVC1G86G
    • Fernon
      • Apr 2019
      • 20
      • Sri Lanka
      Originally posted by wisjg
      U74LVC1G86G
      How to check this two ic
      • ASB
        Asus Prime B450-Plus Bios Modification (USB Overcurrent)
        by ASB
        I have an Asus Prime B450-Plus motherboard with USB overcurrent shutdown problem. All the ports, voltages and resistors are ok. Can someone please help by editing bios to disable this feature? Another member (прямо) has successfully done this and shared the bios in forum but those are for other Asus models....
        11-12-2025, 06:17 AM
      • almirsilvestre
        ASUS PRIME B450 PLUS REV:1.02 bios
        by almirsilvestre
        Hi guys... Does anyone have the BIOS for the motherboard: ASUS PRIME B450 PLUS REV:1.02 If it is working... Because on the Asus website the file exceeds the chip's capacity.
        Thank you very much....
        04-22-2025, 04:58 PM
      • karlp028
        ASUS Prime Z390-A not starting up - possible issue with PCH
        by karlp028
        I'm working on an ASUS Prime Z390-A that isn't reacting to the power button. All of the standby voltages and signals are good. The PCH is receiving O_PWRBTN#, but it is not de-asserting SLP_S3#, SLP_S4#, or SLP_S5#. I started probing around and noticed the voltage on RTCX2 is around 1.5V, which seems crazy high. On RTCX1 it is around 300mV, which is normal. I don't see any waveform either. When the PCH is not powered, the resistance on RTCX1 is about 2.5M ohms and on RTCX2 it's about 8.5M ohms. When the PCH is powered on, RTCX1 shows about 7M ohms and RTCX2 shows OL.
        I suspect the...
        07-17-2025, 06:31 PM
      • rounin
        MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
        by rounin
        🛠 Original Issue
        ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
        04-19-2025, 01:18 AM
      • ugamazing
        by ugamazing
        12-17-2024, 07:05 PM
