ASUS PRIME B450 PLUS REV:1.02 bios
  • almirsilvestre
    • Jun 2020
    • 44
    • Brasil
    Hi guys... Does anyone have the BIOS for the motherboard: ASUS PRIME B450 PLUS REV:1.02 If it is working... Because on the Asus website the file exceeds the chip's capacity.
    Thank you very much.
  • SoporteNetFe
    • Aug 2021
    • 121
    • Argentina
    You need extract cap file....
    • almirsilvestre
      • Jun 2020
      • 44
      • Brasil
      I already do this... But The machine only beeps 3 times.
      I've already tested the one on the website... I used the extraction program... Everything went well... But the machine just keeps beeping... Does anyone have the dump working?
      • almirsilvestre
        • Jun 2020
        • 44
        • Brasil
        I want to thank you... I extracted the bios and it worked... It was my recorder that I think didn't record well the first time... Thank you very much for your help
        Now its working fine​​​
        • almirsilvestre
          • Jun 2020
          • 44
          • Brasil
          Bios Working and extracted.
          • ezenia
            ASUS PRIME B450 PLUS (rev 1.02) USB Overcurrent issue
            by ezenia
            So I bought a faulty ASUS PRIME B450 PLUS motherboard off eBay. They said it was water damaged and they cleaned it. The PC POSTs and displays a message that it's detected USB overcurrent and will shut off in 15 seconds. I verified this myself. So I did some checks at the ATX connector 1st to see if the resistance readings looked OK. I found the 3.3V rail measures just 179Ohms which seems way too low. It's been much higher on other AM4 boards I've worked on.
            So I did some Googling to see what the potential culprits are. It varies from bad protection diodes, bad...
            10-18-2025, 05:06 PM
          • ezenia
            Requesting ASUS Prime B450 PLUS Rev 1.02 boardview
            by ezenia
            Just wondering if anyone has a boardview for the ASUS Prime B450 PLUS motherboard (rev 1.02). It has a USB over current issue I am trying to solve. Measuring the 3.3v rail on the 24-pin ATX connector sees 166ohms which seems way too low. So I'm trying to figure out if this has anything to do with it or if there's something else wrong. Tried to search for a boardview, but nothing comes up....
            10-18-2025, 09:10 AM
          • Geomih
            Asus Prime Asus PRIME X670-P r1.01X (60MB1BU0-MB0A06) boardview
            by Geomih
            Couldn't find this particular board on badcaps so here it is for safe keeping...
            08-16-2025, 01:52 PM
          • DynaxSC
            Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
            by DynaxSC
            Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
            For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
            06-10-2023, 11:30 AM
          • RotVik
            ASUS PRIME B550M-A AC weird behavior
            by RotVik
            Hello, I need a little help
            I got an ASUS PRIME B550M-A AC Motherboard, bad BIOS, it wont display or boot, unless I did CMOS Restart first, after that It will boot but if I modified the configuration of the bios and saved it ,again no image
            I got the BIOS .CAP file from ASUS official support, used a tool called ASUS CAP to BIN, and programmed it to the IC, soldered to the board and got it to boot correctly, all the way to Windows, but now the CPU fan stays at full speed all the time and if I try to power it off with power button it will restart instead, and there are...
            05-01-2025, 04:59 PM
