Asus X99-S motherboard will not start
  • Sully115
    • Sep 2025
    • Wales
    I have an older Asus X99-S mother board which has quit working on me, I don't have money for an upgrade at the moment so thought I would have a go at figuring out what up. Before it stopped working the pc would intermittently not start on the first try, but normally would on the second (I don't know if this is relevant)
    I have tried the usual, reseating everything, using a single Stick of ram etc, tried flashing the bios from USB but nothing happened . when the psu is turned on the power and reset buttons light up but nothing happens when pressed, I have checked the psu and all the voltages are present when I jump it. Cmos battery is fine.
    I have checked the board with a multimeter and 5vsb is fine, goes into the mosfet for 3vsb which is present at the super io onthe right pins (only at 2.6ish volts though). The 3vsb mosfet appears to be getting a little warm and the capacitor connected is getting quite hot (40 degrees), strangely there is a capacitor close by on the 12v rail that is also getting hot but there isn't any voltage across it. When the button is pressed the pin drops to 0v but the psu does not start up an the super io output pin does not change.
    I am at a bit of a loss of what could be the cause without just changing the caps and the mosfet to see if that changes anything. The 12v cap heating up seems to indicate a short somewhere as the is no 12v rail live from the psu.
    I have a boardvoew file from a very similar mother board, the data sheet for the super io chip.
    Would be greatful if anyone has any suggestions
  • DynaxSC
    • Apr 2021
    • 477
    • Poland
    First check whether there is present 5V Stand-by voltage in the big ATX connector.
    If yes, check whether the board asserts the PS_ON signal in the big ATX connector (asserting = low = 0V) after shorting Power On pins in the System Connector.
    If yes, check all input resistances for ATX powers, 12V, 5V and 3,3V. If there is an overcurrent of the PSU due to short on any of these power lines, the PSU will not start and block any further start attempts until unpowered from mains for 2-3 minutes.
    If no 5V Stand-by present look for shorts on the board, i.e. on any Stand-by rails generated from 5V Stand-by: 3,3V and chipset power rails 1,05V, and probably 1,8V (not sure here). Chipset should be always powered even if board is off.
    Chipsets tend to get degraded with long time working, and either get partly broken (working unreliable, no correct POST, or no start at all), getting hot (anything above 55-60 C without radiator on it is suspicious) or get fully shorted power rails finally. Chipset partial or full failure is often the reason for not starting of the board. Such strange behaviour you described is often sign of a degraded chipset. For old boards this means usually RIP, as repair makes economically almost no sense.
    After taking off the radiator from chipset, you can measure the presence of the chipset powers on the MLCC caps mounted on the silicon chip carrier - the inner pads are usually the positive power lines, the outer is usually GND.
    • AppleLover123
      Asus X712EA 3 volts after the first mosfet
      by AppleLover123
      Hey guys,
      i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
      I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
      Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
      I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
      Now i thought something...
      12-15-2024, 07:49 AM
    • Scotchmist
      Asus GA502D keeps blowing mosfet
      by Scotchmist
      I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
      I have removed the mosfet and can run the laptop no problem
      The MOSFET is FDPC5018SG
      Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
      08-24-2024, 02:23 PM
    • MicroSMD Lab
      by MicroSMD Lab
      I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
      01-10-2024, 06:36 AM
    • someonenotyou
      ASUS G513R - cannot remove MOSFET
      by someonenotyou
      Hi.
      I have a ASUS G513R laptop with shorted MOSFET (MP86959GMW-Z 45A).
      I tried to preheat the board to 200C brom the bottom and with rework station set to 400C I flowed it for about 2min. The MOSFET does not come off.
      Of course, I did not force it, but tried to lift it up with tweezers.
      Is it possible, that these MOSFETs are glues to the board? Or it got welded to the board from the short? It looks intact, no signs of blowing up.
      10-10-2025, 11:05 AM
    • Timp74
      Odd MOSFET only on some ASUS x99/x299/z370 motherboards..
      by Timp74
      Hi All,
      Could anyone comment on the purpose of the MOSFET circled in red in the attached photo of an ASUS ROG X299 Extreme VRM?
      I'm trying to fix an ASUS motherboard(WS x299 SAGE) with a similar VRM where this MOSFET has burnt out along with one of the IR3555m driver chips. From looking at photos of motherboard VRMs on the internet, it seems only some ASUS motherboards have a MOSFET like this. Although I've seen some photos of ASUS z370 boards where it's not populated. The MOSFET is usually a NTMFS4C06N. It has its drain connected to the output of the Vcore VRM, and on...
      08-13-2021, 01:11 PM
