Burnt resistor MSI B550 Tomahawk Max
  • baas62
    • Aug 2025
    • 3
    • France
    Hello everyone
    I have an MSI B550 Tomahawk Max Wi-Fi motherboard that has burned out components. See photos below.
    I tested the rest of the board, and everything seems to be working properly and stable. I tested it in-game with a 1650 GPU, just in case, and in Cinebench.
    I didn't install an NVME SSD on the first port but only a sata 6gb classic 2.5 inch ssd
    I checked the warranty on the MSI website, and the board is still under warranty until May 2026, but unfortunately I don't have the receipt to request an RMA.
    Is there anyone who knows who could confirm what theese components are for, whether they can be repaired, and whether there is a security risk in using it this way?
    Thanks.
    Location at the end of the index:
    what it should looks like :
    https://encrypted-tbn1.gstatic.com/s...aRMMpfiH-Q2Hlm
  • noname2024
    • Aug 2024
    • 257
    • CỎ MỸ XỊN
    +12V_VDDP
    • noname2024
      • Aug 2024
      • 257
      • CỎ MỸ XỊN
      SEARCH BOM FILE
      ,CAP MLCC,10uF,25V,X5R,0805,10%,1.25mm,HALOGEN FREE
      • baas62
        • Aug 2025
        • 3
        • France
        Thanks noname2024.
        What are theese resistors on the motherboard for? What exactly does it control?
        • kacangpolo
          KcPOLO
          • Nov 2021
          • 10
          • Indonesia
          i think you're new in this job, let me correct, that component you point is not resistor, that is capasitor, they filtering main power 12V before enter into ic, you can open the boardview
          you can remove that capasitor was broke, or replace it if you have, and dont forget make sure doesnt short in that way after your remove or replace capacitor,
          • CG2
            LED uplighter dimmer burnt resistor
            by CG2
            I've got a 240v LED uplighter which isn't working. Pulling it apart shows a clearly burnt resistor on the circuit board, and I'm hoping some of you will have suggestions on what to replace it with. First, here are some photos. Power comes in, through the fuse and choke, then through the big blue variable resistor labelled B500K (ignore the similar blue component at the bottom - it's a simple switch for an attached reading lamp). It then passes through the burnt resistor (or at least did once), through diac DB1 and the unburned 30 ohm resistor to the gate of the triac.Now I assume there's a simple...
            02-14-2024, 09:23 AM
          • trickartt
            Allen & Heath Xone:02 (DJ Mixer) - Burnt out Resistor
            by trickartt
            Hello Badcaps!
            I am trying to troubleshoot my Allen & Heath Xone:02 DJ mixer. I have had this for somewhere close to 20 years and have played music through it in one form or another pretty much every single day since I've had it, though these days it's usually from a wireless streaming receptacle (Apple Airport) more than the turntables that are also connected to it.
            This week my music stopped working, and after a bit of a wild goose chase, I realised my mixer was dead. I checked the 500mA fuse in the device beside the power supply and found it was blown, so I replaced...
            05-04-2024, 12:07 PM
          • sparcktikus
            Ersa Rds 80 soldering station burnt resistor
            by sparcktikus
            Hi
            I have an Ersa rds 80 soldering station which has developed a fault and just showing err on display
            I have found a burnt resistor on pcb can anyone help me identify this resistor if you have a circuit diagram or similar unit
            The printed circuit board markings are rd80 ver 2.0 and the resistor in question is R6
            Many thanks...
            04-04-2023, 04:29 AM
          • jinu_j
            by jinu_j
            Hi
            05-03-2025, 10:51 PM
          • mikey5791
            Need help to replace burned resistor in 350w atx psu
            by mikey5791
            Hi to all forum members,
            Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
            The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
            Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
            Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
            12-26-2024, 04:55 AM
