Re: Creative Sound Blaster 16s with incorrectly capped TEA2025 amplifiers
For whatever reason, I never noticed this thread, and I even made a thread of my own, dedicated to refreshing the SB16. Obviously, I took things a step farther, in some ways, with a refreshed motherboard and PSU to stiffen the power delivery and increaae stability of the system in general.
But I wanted to address some minor things, which were commented on in the thread:
One user commented that you must use passive speakers with the SB16's output. However, as with most amplifiers, this is not entirely true. You may also use headphones, but you do need to be wary of your volume-levels as the output-power is quite high on the Speaker-Out. As far as impedance is concerned, the data sheet only scales to 16-Ohm IIRC, but I have used 24-Ohm headphones on my refreshed SB16, and I can barely turn the volume up within Windows when running directly off the card. (Maybe the low-impedance caps)
There seems to be confusion as to why one would use bipolar capacitors in the signal-path--this is because audio signals exhibit A/C-like characteristics which are better reflected through bipolars.
The way I understand it, larger you in value you go in capacitor, the farther down you generally bring the ceiling as concerns frequency handling. On inputs, often a careful combination of capacitors are used, one bypassing another--the combination often consisting of 1.0uF and 0.1uF, and sometimes the addition of an even smaller capacitor. But placement must be sequential or you will defeat the purpose of one or more.
Matthew
Matthew
what did we say about hoarding too much stuff and depriving others of them?! *cough* socialism *cough* lol!
