RTX 3080 FE Identifying capacitor
  • Prolog
    • Dec 2024
    • 6
    Hi people, I hope this is the correct spot to post this, I'm new to the forum.
    I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
    I hope these photos make it clear which component I am referring to:
ID:	3519409Click image for larger version
ID:	3519410 (yes, the soldering is a bit botched from removing the blown one, I know)
    I have found the board schematic (attached), but there does not seem to be a boardview available. I have never really had to read schematics before, so I am a bit overwhelmed by it and haven't been able to figure out the capacitor values based on the schematic, but according to this video (https://youtu.be/THMukcOzB8g?si=vO7_O-d4__kqye8j&t=1311) the large capacitors next to it are output filtering capacitors. I hope someone is able to help me out here.
    Thanks in advance.
    P.S. The reason I found the burnt capacitor in the first place is that the gpu is having issues where it boots up ok, but under a little bit of load the fans spin up a lot and it heats up quite a bit, before eventually crashing. There is also a black burn mark on the gpu heatsink above above these capacitors. I am hoping replacing these capacitors fixes the issue, but let me know if that is unlikely to be the root cause.
  • noname2024
    • Aug 2024
    • 243
    • CỎ MỸ XỊN
    12V_EXT8_NVVDD_PH9_VIN
    CAP PL 270UF/16V 6.3*8 20%
    • Prolog
      • Dec 2024
      • 6
      Thanks for the quick response noname2024. I am assuming that 6.3*8 is referring to the dimensions in mm. However the component I am looking for is actually closer to 1mm in length and less in width. Is the capacitor you mentioned an equivalent replacement but in a different package?
      • Prolog
        • Dec 2024
        • 6
        ^ could anyone provide a second opinion?
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3593
          • slovakia
          there are MANY other capacitors on that line. u dont need them or throw in any of suitable package.
            NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
            The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
            10-02-2024, 08:52 AM
          • Ambro
            Help identifying missing smd capacitor for HP elitebook 840 g3
            by Ambro
            In an unfortunate mishap while attempting to read from the bios chip, one of the smd capacitors took flight and disappeared.
            I'm not sure how crucial this smd capacitor is, but it was a brown possibly ceramic one with no notable markings on it anywhere.
            I've attached a picture of where it's located on the board.
            Does anyone have an HP elitebook 840 g3 who might be able to aid me identifying this component. I'm not sure how crucial it is, but didn't want to risk it.
            Thank you for any help you can provide....
            09-09-2023, 06:21 PM
          • grimacelord
            Need Help Identifying Capacitor On Kar-Tech Versa Remote
            by grimacelord
            I have sort of a weird one here. This is the circuit board for a Kar-Tech VERSA remote. It's a wireless transmitter for crane and other heavy equipment.
            One of the capacitors have blown and I need help finding a replacement. The capacitors are 11.4mm x 6.6mm in size and the only imprint on them is "200mΩF", which I am assuming means 200 microfarads. There is no other markings on them. I have tried doing some searching on digikey and mouser, but I can't seem to find anything like this on there or I am inputting the wrong search parameters....
            09-08-2023, 09:28 AM
          • krob80
            PS5 Edm-010 No Power - Help identifying missing capacitor
            by krob80
            Hey everyone. I recently acquired a PS5 that is not turning on (no beep/power). PSU is good and there is no shorting on the 12V rail.
            It came with a Gen3 SSD installed so I feel that things went down hill for the previous owner when it was installed. F7003 was blown but there was nothing shorting to ground. I replaced the fuse but still no power (new fuse is still good for now).
            When connecting it to a bench power supply, it only pulls 10 mA (doesn't spike when first connected).
            I noticed that there are a couple capacitors missing from the Vcore power regulator (pictures attached)....
            05-15-2025, 04:24 PM
          • chunk69
            Looking for help in identifying Kuang Jin capacitor from PSU
            by chunk69
            Hi friends,
            I recently acquired an old PC power supply (along with several vintage motherboards from late 90s/early 2000s). The PSU was dead upon first test, but quickly identified the internal fuse had blown. I fixed that, re-tested and i'm pleased to report it seemed to work great after that - no obvious issues or reasons for the fuse to blow.
            Afterwards, I inspected the capacitors more closely and noticed one pair required replacement. They weren't in bad shape by any stretch of imagination, but one was slightly bulged, and I wanted to swap them out for good measure....
            12-06-2023, 04:35 PM
