board after start show 00 post code - where to search for fault
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3630
    • slovakia
    Hello.
    Have some boards that shows 00 post codes when started. flashed bios, check voltages. I suspicious chipset dont comunicate. Any hint?
  • DynaxSC
    • Apr 2021
    • 477
    • Poland
    There are a 100 reasons possible for that. Have already given some tips here:
    https://www.badcaps.net/forum/troubl...but-no-display
    To give an example, I had once a board with same symptom, the reason was one bloody 0402 mlcc cap with a short in the power sequence logic. I found it by using root cause analysis tracking back the signals having wrong statuse to the source of the problem. But this is one of 100 possible reasons. Often also partially demaged chipsets are the reason - yes, this is possible and is not so seldom. Eg. I recently got a board which started to work by pressing down the chipset solicon with a finger. Thaught it needs reballing, did it twice, but did not help. That means that the chipset is demaged internally, some signal did not conduct, eg. a bonding of the chipset carrier board to the silicon is not reliable. Pressing helps, heating helps for a moment, but then it gets back to non-working condition. Chipset must be replaced even though it is principally ok.
    • spleenharvester
      Tower T548006 battery, fault on BMS board
      by spleenharvester
      I have two of these spotwash machines. They are portable systems that use a 12V power tool battery consisting of three 18650 cells. One of the batteries recently failed. 12V appears at the terminals but there appears to be a fault condition - machine flashes LEDs when you attempt to power up. When you plug in the battery directly (the machine charges through a USB-C port, but there is a second USB-C port on the battery itself for some reason that can also be used for charging), the green LED lights and a dim red LED lights next to it solid. By comparison, a working battery will flash green only....
      10-04-2025, 06:33 AM
    • tony359
      2007 Macbook logic board fault
      by tony359
      Good day all,
      I got a 2007 MacBook from a friend. The fan was not working so it was overheating.
      Once the fan was swapped, I installed an OS and it worked fine.
      The board had quite a few corroded spots so I removed it, touched those spots with a soldering iron, washed the board in PCB cleaning fluid (I've done that many times), rinsed it with distilled water, dried it etc.
      Unfortunately it doesn't work anymore. It does turn on, fan spins, power LED turns on. But no picture.
      If I see that right, I have missed VCORE on L7100 (page 59)....
      01-23-2025, 06:59 AM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • Hakuu
      by Hakuu
      Hi There,
      More Details
      TV Model - LG OLED77G1PUA
      07-12-2023, 02:37 PM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
