Asus P8P67 Evo
  • luke10050
    • Mar 2013
    • 209
    Asus P8P67 Evo
    Hello, recently i acquired an Asus P8P67 Evo, the board does not post and gets stuck on initialising the cpu (according to the error LED's). the CPU does get power and i have absolutely no idea what to do, all i know is that a PCI card was pulled from the board while running.
  • Agent24
    I see dead caps
    • Oct 2007
    • 5065
    • New Zealand
    Re: Asus P8P67 Evo
    Quite possibly the incorrect removal of a card during power on caused damage to the chipset. Unlikely to be an easy fix, unfortunately.
    -David VanHorn
    • luke10050
      • Mar 2013
      • 209
      Re: Asus P8P67 Evo
      acting on the assumption it is a damaged chipset, how hard would it be to replace it with only a hot air rework station and a heater for the underside of the board?
      • Agent24
        I see dead caps
        • Oct 2007
        • 5065
        • New Zealand
        Re: Asus P8P67 Evo
        It's doable, apparently. Not easy though. You would need practice and learning the characteristics of your tools first to have a good chance of success. BGA is easy to screw up. Hopefully there is something else you can try first, but I wouldn't know where to start. Someone else can probably give advice there.
        -David VanHorn
          • 31246
          Re: Asus P8P67 Evo
          before you do anything rash,
          it's more likely the card was pulled at an angle & shorted some connections together.
          i'd get a copy of the pci pinout,
          and then power the board up wihout a cpu (for safety) and probe all the supply voltages on the pci slot.
          it could just be a blown transistor or regulator.
          • luke10050
            • Mar 2013
            • 209
            Re: Asus P8P67 Evo
            So you're saying its possible the chipset or other essential components are not getting power, should check that out, thanks for the help! This is my first time doing anything but recapping
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
            • DynaxSC
              ASUS STRIX Z490-F GAMING - No POST, stubborn board
              by DynaxSC
              I have this very stubborn ASUS mobo on the bench, and I already face the wall with it. It just refuses to POST, although everything seems to be OK.
              The situation looks like this:
              After connecting the board to the power supply on Nuvoton (SLP_S3#, pin 64), the Low signal (50 ohm resistance) appears immediately. PWRNTN# signal goes through Nuvoton to the chipset (confirmed after removing the chipset). The following conditions are then met for the chipset to generate the SLP_S3# signal:
              1. RTC oscillates normally (32.768KHz).
              07-08-2022, 05:45 AM
            • howardc64
              by howardc64
              07-24-2025, 05:17 PM
            • ShadowAi12
              ASUS ROG STRIX B550-F GAMING — Board not powering on properly
              by ShadowAi12
              I recently bought an ASUS ROG STRIX B550-F GAMING motherboard that was listed as "dead, not powering on." However, it does show some signs of life. I've performed several basic measurements and would like to share the results.
              • The board enters a "ready to power on" state after plugging in the PSU.
              • Pressing the power button increases power draw.
              • Sometimes, touching the RSMRST_L pad with a multimeter probe causes the board to shut off and return to standby.
              Measurements:
              (taken after pressing the power button, while the board is attempting to start)
              • H_SKTOOC#
              06-11-2025, 01:05 PM
