Firebat T8 Plus T8PLUS_V12 damaged during probing
  • spleenharvester
    • Mar 2010
    • 921
    Hi all
    I added a Noctua fan to this dual NIC system at the DC jack, but this of course meant the fan was always on. I was probing for a 12V RUN point and my hand slipped. Now there are two problems - (1) the NIC closest to the power jack is now completely dead, no LEDs and not detected in device manager, and (2) the system is in a constant state of powered on - if the system is shut down it just turns on again a few seconds later. Apart from this the system and the second NIC are still working fine.
    I've added a red arrow to where I was probing when my hand slipped, and the smaller blue arrow shows the direction in which my hand slipped. I definitely shorted the SMD electrolytic cap to the SOT23-6 IC but there was also a spark by the now-dead NIC and I'm not sure what I hit there. The SOT23-6 IC seems to read D5KE or D6KE with a 32 at the end, but that doesn't return any results so I'm not sure what it is. Have I probably just killed this IC or have I damaged something further downstream? I can live with the broken second NIC but the issue with the power being stuck on is really irritating. (It's occurred to me I could get an e-key RTL8111 NIC as I have a slot spare and either wire it separately in the case or somehow wire it to the existing dead port)
    If anyone has a schematic for this board that would also be awesome, but I doubt there is one circulating.
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • spleenharvester
    • Mar 2010
    • 921
    Okay so I see there are various forms of RTL8111, if I am interpreting correctly it looks like some can take 1V and some can take 3V3? And I know power switches tend to involve shorting 3V3 to GND. Is it possible that the SOP-23-6 is a 12V to 3.3V step down that I have killed and as a result both the power button and nearest NIC have failed, but that the working NIC is powered from the 1V rail so is unaffected? I'm not sure anything else on this board takes 3V3 so it might explain why nothing else has stopped working?
    Only SMD parts starting with D5 I can find that might be relevant are NPN/PNP transistors, possibly ROHM EMD5/UMD5N?
    E: Taken another look, it's definitely a SOT23-6 so not the ROHM IC. I've attached continuity tests from that area, it looks like I have definitely killed that IC at minimum as 4 of the legs are shorted together but they are not to ground. Now just the fun of trying to identify it? I'm wary of taking any measurements while the board is running as my tremor is what caused me to slip to begin with and I am worried about causing further damage.
    • spleenharvester
      • Mar 2010
      • 921
      Someone on another site has identified it as probably being an AO6405 MOSFET so I am going to replace it when I get a slow day!
      I guess this explains the inability to switch off but the NIC is a different fault. Nothing obvious probing round the area, I assume I have killed the RTL8111 itself so might just have to accept it.
      • XxMicroSoldering
        ASUS Rog Strix G17-712LV Laptop Liquid damaged
        by XxMicroSoldering
        Hello Guys
        I have a ASUS Rog strix laptop that I bought recently to fix and the previous owner spilled water on it . He brought it into a repair shop for them to check it out and instead of fixing it they damaged the battery connector of the laptop ! Other than that they damaged damaged nothing . But since the liquid damage the laptop only turns on and the keyboard lights up and then immediately turns off. I really want to repair this laptop and I also have experience in repairing phones etc and laptops and a bit of soldering but the diagnosing part is where I need help with and...
        10-17-2024, 10:45 AM
      • Tomylee
        Identification of Component T5 on NEXIQ USB-Link 2 (damaged due to crushing)
        by Tomylee
        I'm currently repairing a NEXIQ USB-Link 2 that was physically damaged due to crushing. After a thorough inspection, it appears that only one component is visibly damaged: the T5 component, located right next to the Mini-USB port.
        It's a 4-pin SMD component, with one pin at each corner, aligned front-to-back along the USB port axis. Unfortunately, it is broken, and there are no visible markings left on the part to identify it.
        I'm looking for help with the following:
        The exact identification or part number of the T5 component
        05-28-2025, 12:42 PM
      • tofik
        LG 50PA6500 Plasma TV damaged after a power spike
        by tofik
        Hello, I have an LG 50PA6500 Plasma TV, purchased new in 2012.
        Unfortunately plasma is not working at all after a power spike.
        Qucikly tested the PSU and voltages seems to be okay, when eveything is disconntected from the PSU I got:
        VS = 200-206 / actual = 205 V,
        VA = 55 / actual = 54.9 V,
        M5V = 5.2 / actual = 5.19 V,
        17 = 17.24 V,
        5.2 = 5.19 V,
        STDBY = 5.19 V,
        ERROR_DET = 4.8 V - does it mean PSU is damaged? the rest of the voltages seems to be fine.
        what's your opinion about the PSU?
        Also I just...
        12-20-2022, 03:08 PM
      • Qhuy
        Razer RZ09-O328, Values For The Damaged Capacitor?
        by Qhuy
        Anyone knows the value for the damaged capacitor for the Razer RZ09-0328, Board number is DA550-mb. Please see pictures. Thanks in advance.
        11-05-2025, 09:48 PM
      • phantomEVO
        [help]820-01521 WATER DAMAGED
        by phantomEVO
        HELP! audio board+its flex+powerbtn flex water damaged (an hole on audio board)!!! chnged both, but i have 5v on both ports:
        https://files.fm/f/6gjpqyjw3q
        here some measurements
        ppbus_g3h 12,29v
        PP3V3_G3H 3,29v
        pp3v3_upc_xa_ldo pp3v3_upc_xb_ldo 3,27v
        PP1v8_UPC_XB_LDOD PP1v8_UPC_XA_LDOA 1,8v
        PP1v8_UPC_XA_LDOD PP1v8_UPC_XA_LDOa 1,8v
        PP1V1_UPC_XA_LDO PP1V1_UPC_Xb_LDO 1,1v
        with battery connected, as soon as i connect the cable, i see direclty 20v, but stuck at 0,0250
        10-24-2025, 04:23 AM
