Help, 38.4MHz xtal has no output on MSI z690
  • McWhitePink
    • Apr 2023
    • 103
    Can anyone help me, why the board doesn't have 38.4M xtal output? Is it the XTAL dead or the PCH dead? for this reason, the board doesn't power on.
  • beogeek
    ASUS ROG STRIX Z690-F DEAD
    by beogeek
    Hi Folks,
    I have an ASUS ROG STRIX Z690-F that has a shorted and dead NUVOTON NTC6798D EC IC and a NUVOTON 3961AF, which appears to be the FAN driver for a chassis fan. I can source the EC and the fan driver, but my question is, will the EC need to be programmed or not? If so, does anyone have the dump for the EC IC and BIOS?
    Cheers!...
    12-11-2024, 07:36 AM
    NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
    I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
    I bought this from an eBay seller but unfortunately they only had one
    I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
    I bought three of from them to also make battery packs with this output power limit in mind
    I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
    04-23-2025, 05:50 AM
  • Joekhoe
    Sharp Aquos Quattron LC-52LE835X Totally Dead, no output voltages
    by Joekhoe
    Hello all, I'm Joekhoe, a newbie here and ask your masters permissions and solutions for the problem i'm facing at the present.
    I am in the middle of working on a SHARP Smart TV model LC-52LE835X from my customer, which totally dead and there's no output voltages at all at the output pins even though i have replace some of the components the output voltages remain the same with 0 volt.
    The replacement as follows:
    1. IC7905 : TNY264PN (first found exploded)
    2. Q7915 : BT169D (exploded too)
    3. IC7901 : 1608B (controller ic)
    4. IC7601 :...
    09-17-2020, 05:52 AM
    Corsair CX750M [Model 75-002019] - burned output toroid inductor
    by momaka
    Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
    So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
    09-19-2021, 08:44 PM
  • CoppellTVRepair
    Troubleshooting PFC with SPC1012T not raising output
    by CoppellTVRepair
    It has been a long while since I posted here to ask anything....hope you can help.
    I have this Samsung power supply that uses SPC1012T as driver for the PFC and it's giving me a problem that I can't narrow down though I've troubleshooted and fixed hundreds of boards similar circuits.
    I am attaching a schematic from a different Samsung board, but the topography is very very similar if not 100% the same and it uses SPC1012T, which BTW is a pinout match to UCC28063 for which there's plenty of information. I haven't confirmed they are functional equivalents, but I strongly...
    03-09-2025, 10:38 PM
