Just finished fixing this one. Apparently, this is a common issue with all Asus P5 series boards. I first assumed it's a bad BIOS flash or corrupt CMOS settings, as it would go away once after resetting CMOS, but upon the next reboot it would be there again. Same if i changed any BIOS settings and saved them.
I read that people have flashed BIOSes to no luck, and someone pointed towards a transistor on another (older) board, so i proceeded to look for a hardware issue. And i found it. See attachments for fix.
Instructions:
This should apply to *all* boards that exhibit this behavior, obviously the parts may be in a different location. Follow these directions to find it if your board differs:
The rest is the same as above.
I'm also going to tell you what causes the issue to appear in the first place in a follow-up post.
Instructions:
- Follow directions in pictures
- Clear CMOS
- Power board up, redo all BIOS settings
- Be happy and have a cold one.
- Remove jumper cap from chassis intrusion connector (if you're reading this, you already found it's of no use anyway).
- With the board powered ON, measure with your voltmeter and find the pin of the chassis intrusion switch connector that has somewhere between 1.7v and 3.3v on it.
- Disconnect board from PSU.
- Use continuity tester function of your DMM and probe on the SOT23 transistors next to the super IO controller, you should find it beeps on one of them.
- Power the board back ON and find a 3.3v supply nearby
- Power board OFF, remove transistor, solder drain connection (it's gonna be the single pad, just like it looks in the picture) to 3.3v supply.
