Epox 8RDA+ (UK sourced board)
  • happytechie
    • Jul 2004
    Hi All,
    My Epox has died and I need to replace the caps. The poped / bulging ones are:
    4 * 10mm 10v 2200uF
    2 * 8mm 6.3v 1500 uF
    5 * 8mm 6.3v 1000uF
    all the dead caps are ECS branded and all of the sanyo branded ones are fine.
    If anyone knows where I can source these in the UK that would be great :?
    (does anyone know how to get the correct symbol for pico? )
    some pictures for your pleasure:
    thanks all, a good resource is building up here
  • happytechie
    • Jul 2004
    epox say:
    Dear Sir,
    Many thanks for your e-mail.
    I am afraid that the images shown do not relate to capacitor failure by term of “low grade components” as you state but is in fact a symptom of a thermal or current problem within the system. I am afraid that such damage to the mainboard is outside of the mainboard warranty. This failure mode is not a mainboard failure and certainly not through the use of “low grade components”.
    EPoX UK FAE
    http://www.epox.org
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16956
      That's a crock! That's CLASSIC of low-quality capacitors. They're just trying to weasel off the hook... You're better off recapping it yourself, you already see how crappy their support is just by that email... You can only imagine the quality if the repair they would do...
      Sanyo caps are not prone to fail, they're good quality. The rest on the board are junk, and their quality has shown its true colors.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • happytechie
        • Jul 2004
        thatnks for that Top cat, I know it's nothing to do with the rest of my system as the PSU has rock solid rails and the case is a well cooled cooler master.
        Anyway, I didn't really expect to get any help form Epox uk so does anyone know what type of capacitors I need?
        product codes from farnells would be ideal
        the caps are
        10mm 2200uF 10v
        9 or 10mm 1500 uF 6.3v
        6 or 7mm 1000 uF 6.3v
        I assume I need electrolytic capacitors but the farnell catalogue starts asking me about drift tolerances and min and max temps, my high school level electronics knowledge is now fully exausted
        thanks in advance
        HT
        • kenjabi
          • Aug 2004
          I had the exact same problem with my first 8rda, the caps looked exactly the same. Bulging white stuff from the tops, and it was replaced under warranty from Epox (through Aus distributor).
          The replacement they gave me is now bulging too. :roll: :roll: :roll:
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            total bullshit!
            all mfrs should know about the crap cap fiasco by now.
            maybe drop em a link to here to educate them.
            tell em its time to pull their head out of the sand.
            Originally posted by happytechie
            epox say:
            Dear Sir,
            EPoX UK FAE
            http://www.epox.org
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              http://uk.farnell.com/
              do a search for "rubycon zl" they have the specs you want.
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
              • howardc64
                by howardc64
                07-24-2025, 05:17 PM
              • Hakuu
                by Hakuu
                Hi There,
                More Details
                TV Model - LG OLED77G1PUA
                07-12-2023, 02:37 PM
              • jb_Bak
                by jb_Bak
                CN6401
                Pin 01 NC
                Pin 02 NC
                Pin 03 "BL_ON": 0V
                Pin 04 "N/C"
                Pin 05 "STBY 3.3V": 3.5V
                Pin 06 "GND": N/C
                Pin 07 "AC_OFF"...
                09-27-2021, 04:52 PM
