17" Imac G5 replaced caps, still won't turn on :c
  • Zeigren
    • Apr 2013
    • 5
    So I've got two 2004 Imac G5's that I've replaced the bad caps on, but they both still don't work. I bought the kit on here for one of them and the other one I ordered all Nichicon caps from digikey for. Whenever I try to turn either of them on nothing happens, I get LED 1 but nothing else.
    Unfortunately I only have one PSU between the two so that possibly could be it but the caps look ok and I figured the second LED would flash if it was a PSU problem. But just in case I'm going to look up the pin-out and try and test it, maybe even make an ATX adapter so I can use a power supply that I know works.
    But I was wondering if there could be any other problems? If maybe the video card on it had died and that's why it wouldn't turn on? Maybe a reflow for the GPU would fix it? Thoughts?
  • cheapie
    null
    • Jul 2010
    • 849
    Re: 17" Imac G5 replaced caps, still won't turn on :c
    Pics?
    Also, are you getting the right voltages from the supply?
    • Zeigren
      • Apr 2013
      • 5
      SO maybe I posted prematurely haha. I checked the voltages on the supply and oops they were all terrible. Only one 5V worked and the 24V read as 20.9V but everything else gave me a nice 0V. So I modified a ATX PSU to work with it and now both boards work! Although one of them has some graphics problems so I'm going to have to reflow it but other wise success!
      I also managed to get the other PSU from the previous owner, which does the exact same thing as the other PSU. So now I have two I have to fix :p
      • tron
        • Apr 2009
        • 47
        "otherwise"
        • smason
          • 1652
          Originally posted by tron
          "otherwise"
            by momaka
            03-15-2023, 10:17 PM
          • ryogadan78
            iMac A1311 - Motherboard 820-3126-A, turn on sometimes
            by ryogadan78
            Hi guys, I have this 2011 iMac A1311 with a strange problem.
            Most of the time, when I plug in the power cord, the first of the 4 LED's turn on, but when I press the power switch the LED turns off and iMac won't boot up.
            Sometimes, when I unplug and plug the power cord back in, iMac starts up correctly by turning on the 4 LEDs in sequence.
            I have already tried a new power supply, but the result does not change. Do you have any suggestions?
            Motherboard 820-3126-A​
            04-06-2024, 05:19 AM
          • reessi
            Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
            by reessi
            Hello:
            I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
            I started on the ACER:
            Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
            All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
            I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
            10-29-2024, 11:31 AM
          • zlr8r
            HP Probook 640 G5 - replaced blown components, getting power led, fan full, 5-flashes on CAPS Lock and NUM lock, black screen
            by zlr8r
            Hey guys, bit stumped with this laptop after replacing 2 blown components i.e., MP86493, MP2979A.
            To begin with, this laptop was dead-dead.
            Now with replaced (visibly) blown components, i do get some progress; after connecting battery or main cable;
            • am getting white power led
            • 5-long-flashes on CAPS Lock and NUM lock
            • then, fan full speed
            • CPU heats up some (smaller die PCH, does not)
            • always constant black screen no matter what's tried
            • no USB recognition
            • no HDMI output
            this is as far as I can get with it and not sure where to inspect next ?
            I tried...
            03-27-2024, 03:13 PM
          • bcstedt
            LG 42LB5D, 42LB5DF-UL, 2008-01, Power On Issue, Replaced PS Caps
            by bcstedt
            LG 42LB5D (42LB5DF-UL) from 2008-01, unit is in good shape and no obvious heat damage or cracked solder on the boards.
            Problem:
            On first power-up the power LED flashes green about 18x and then stays solid. No backlight or image is present. Click power button, wait 10s for a click and the LED turns red. Wait 1-2s and hit power again and maybe it'll power up fully after 6 green flashes. If it doesn't light up on the sixth flash then the cycle repeats.
            It seems that if the mainboard power is left on for a few minutes (solid green power, no backlight, no image)...
            01-18-2024, 01:03 PM
