ASUS VW246H backlight cuts out in 1-2 seconds
  • norcalx360repair
    • Nov 2011
    • 12
    Hi, someone brought me an ASUS 24 inch monitor(VW246H) and the backlight cuts out very quickly. Video is still ok confirmed with light. I googled this every which way and there isn't much info on this problem.
    I opened it up and this one has PSU and inverters on one board. Board number is 4h.onc02.a01. All caps and everything else looks good on it but I know this doesn't mean they aren't bad.
    I was hoping someone has seen this before. I don't work on monitors or tv's much at all and this is for a coworker so free type thing to try to help him out. Any help would be greatly appreciated.
    I found similar PSU/Inverter boards on ebay for like $22 shipped but they aren't exact model.
    Thanks!
  • Hemingray
    KABOOM!
    • Jul 2010
    • 143
    Re: ASUS VW246H backlight cuts out in 1-2 seconds
    I would check the caps. I have a 15" Hansol that did this exact same thing, and none of the caps were bloated, however I found a 470uF cap near the backlight inverter had failed (lost most all of it's capacitance). Replacing that brought it back.
    • norcalx360repair
      • Nov 2011
      • 12
      Thanks for reply. Unfortunately, I don't have any way to even check capacitance now. I actually found the service manual for 26 inch version and I believe they use the same board. I'll check more and report back.
      Last edited by Uranium-235; 05-29-2013, 01:01 AM. Reason: sorry, thought it was my post, didn't reload my post when I hit the back button
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        for a monitor this big, and expensive, I would replace every single cap, including the small ones (starter caps)
        edit: correction. I would try to replace every cap but the biggest one first (including the small caps). If that fails, replace the big one
        Last edited by Uranium-235; 05-29-2013, 01:02 AM. Reason: this is my post. there are many like it but this one is mine
        • norcalx360repair
          • Nov 2011
          • 12
          I'll see if I have suitable replacements and report back. I have plenty of other boards I can check. THanks.
          EDIT:No suitable replacements. I found that there is another compatible board part number. 5e-0nc02-001. Can't find it anywhere though.
          • norcalx360repair
            • Nov 2011
            • 12
            When the backlight does come on for a quick couple seconds or so the screen is bright. I've been reading and some people say this can be due to a bad backlight tube but it will seem more dim than it should be. Since it is bright it doesn't sound like that is the issue, right?
            I actually found a replacement power/inverter board but would suck if it ended up being the tube.
            • rs2klee
              • Jan 2020
              • england
              i kinda have the same problem is to why i joined the site, same monitor powers on then flash`s the screen then goes off, but the blue power light still stays on!
              • ktmmotocross
                Asus G513QE keyboard and backlight not working
                by ktmmotocross
                Have this Asus G513QE with keyboard, keyboard backlight and Led backlight not working. other works ok.
                i measure all voltages ok on keyboard, KB backlight and Led backlight. looks like a kbc error.
                but as laptop works i think it cannot be bad. maybe its FW. have anybody some hint for this?
                08-08-2025, 06:29 AM
              • user546087
                Keyboard backlight too bright - Asus Zenbook S16 / UM5606
                by user546087
                I have a new Asus Zenbook S16, Model UM5606. Unfortunately, the keyboard backlight is too bright, even on the lowest setting. I have explored several ways now:
                - kindly ask Asus for an adjustment - they basically told me to STFU and get lost It is not possible, they say. Of course.
                - tint the keycaps from behind - I have already tried that - it is kind of a last resort
                - try to find out, how it is done, look at schematics - this is, where we are at.
                - maybe get the BIOS modified somehow? This would be the best option but I do not know a lot about...
                02-24-2025, 02:03 AM
              • FallenOne008
                Asus G712L No Screen Backlight
                by FallenOne008
                Hi everyone, hope all is well. I have run into a problem where my backlight screen is no longer working.
                The original screen was beginning to show signs of faultiness. I believe it was part of the inverter board that was going bad. The backlight for the screen was still functional at this point. Well one night as I was tinkering with the laptop, my idiot self forgot to disconnect the battery from the motherboard. I attempted to reconnect the EDP cable onto the motherboard, and as you might guess, I saw a nice spark from the cable and the port. Don't worry, I'm still kicking myself...
                03-31-2025, 08:27 PM
              • hardwareserwis
                Asus Strix G513QR logo appears, then only the backlight stays on
                by hardwareserwis
                Asus Strix G513QR-HF016
                Motherboard: G533-MP-GBM, 6050A3250202-MB-A01
                The motherboard powers on, the Strix logo appears, then only the backlight stays on — it does not enter the BIOS and hangs at that stage.
                The laptop arrived with a broken screen and a damaged display cable.
                Actions performed:
                • New BIOS dumps have been flashed
                • A new Ryzen 7 CPU was soldered in (tested with two different units), but the issue remains the same with both
                • Tested with a different display cable and screen
                • No missing components or visible damage on the motherboard; no components
                09-29-2025, 01:02 PM
              • obdcart
                Asus X415ea Adding a Keyboard with Backlight
                by obdcart
                Hello my friends i hope you can help me, i have just replace a keyboard with non backlight on a Asus X415 Laptop and i already install a Keyboard with backlight, the motherboard has the conector and ic's to control the light but i doens't work, i already try with a new installation of Windows and it's the same and injecting 3v/5v to the backlight flex it turns on the light, i think must be disable on Bios or need a jumper configuration.
                I hope you can give me some help
                06-28-2024, 02:21 PM
