Abit BF6 - only starts once
  • doggyfreestart
    • Feb 2006
    • 10
    So here is this BF6 with a pretty funny behavoiur:
    If I start it just after plugging in the PSU, it work all OK. Soft reset goes as well. But as I drive it down, and want to start it again, it doesn't make any sound.
    I have to detach the PSU, wait a few mins and I can start then again.
    The Caps look allright, althought they are Jackcons.
    Is this problem typical for bad caps? If not, what else can be wrong?
    Thanks in advance,
    George
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Abit BF6 - only starts once
    yup
    can be badcaps in the psu also...
    • doggyfreestart
      • Feb 2006
      • 10
      Yes, 100% correct remote diagnostics.
      PSU was wrong.
      All in all, every PC problem has 2 roots:
      1) Bill Gates
      2) Bad caps
      • MD Willington
        • Sep 2004
        • 702
        I find them all the time at work, I have a dead BF6 in my spare parts pile, one of the developers on the other side of me has a dieing BF6 Linux box... I told the IT guy to get me the caps and I'd fix it during my coffee break...
        Ya'll think us folk from the country's real funny-like, dontcha?
        The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
        • chaos-theory
          Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
          by chaos-theory
          I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
          Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
          03-14-2025, 05:37 PM
        • Foetuss
          Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
          by Foetuss
          Hi all
          Hope this is in the correct place.
          I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
          Could use some double checking to see if I'm not doing something stupid .
          Pictures of the boards are attached.
          What I will be replacing with what : (planned)
          Soltek Golden ::
          4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
          6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
          01-18-2025, 11:44 AM
        • arabex21
          Asus Prime B450M-A starts only when 12v 8pin cpu plug disconnected
          by arabex21
          Hello everyone. I have been reading this forum for a long time - I really appreciate the amount of very interesting materials and information in the field of electronics.
          I have a problem with this configuration:
          ASUS PRIME B450M-A
          RYZEN 1300X (I replaced it with ATHLON 200GE - the same behavior, the processors are functional, tested on another board)
          When the entire set is installed (CPU, RAM, ATX connector and 12V 8 pin CPU plug), the board starts up for a while (about 1-2 seconds), the CPU fan starts and the board turns off immediately. When I disconnect...
          09-19-2024, 03:05 AM
        • master3112
          Lenovo E15 Gen.3 NM-D481 No starting and charging via USB-C, The device starts only via the battery.
          by master3112
          I have a Lenovo E15 Gen.3, motherboard NM-D481 with a defective USB-C port. The device starts with battery. When connected to the USB-C power supply, it does not start or charge. 20V is present at the input of the UT5 (High voltage USB PD power switch), 0V at the output
          UT5 pin 3 (SNK_PS_EN) =0V
          RPT3 Pin1+2 LDO 3V3 present
          I suspect that the UT2 USB-C power controller is defective because the UT5 is only controlled by the UT2. However, the UT2 supplies on pin 33 (+LDO_3V3) which makes me wonder if it is defective after all. Unfortunately I don't have it here to test it.
          08-02-2025, 12:30 PM
        • Shobos
          Dell E6420 XFR Rugged starts to boot but after 3 secs shuts down.
          by Shobos
          Hi, I bought 6420 XFR that tries to boot but shuts down after about 3 seconds, CPU gets warm, fan starts.
          So far I have tested all rails wich are good, BIOS flashed with CH341, 3.3,5, main rail present. multiple ram sticks tested. Sometimes it might stay on for longer like 4-5 seconds but not always, theres no picture whatsoever. Also on some rare occasions the caps lock flashes 1 time by itself.
          NOTE: I am using bench power supply not dell charger with ID pin and NO battery present, kinda doubtful this would cause this issue.
          Any help is welcome. Thanks !
          07-29-2025, 03:53 PM
