Two different graphics cards with continuity between the PCI-E connector pins
  • SuperDuty
    • Mar 2011
    • 299
    • France
    Hi guys,
    I have a Manli GeForce 9600GT and a Biostar HD4850 graphics cards that have both the same problem : they short the PSU as soon as the PCI-E connector is plugged.
    Now upon inspection, I've noticed that there is continuity between all the pins of the PCI-E connector on both cards between the GND and +12V. I'm pretty sure it's not supposed to be this way as I have made the same test on my other video cards with a PCI-E connector and none of them show continuity between the GND and +12V pins. And that's on at least ten other video cards, including two other 9600GT and two HD4850.
    There is no sign of damage anywhere.
    I've checked all mosfets and caps, they're all good. Could this be internal to the board itself ? Two layers could be in contact ?
    What could I check now ?
  • SuperDuty
    • Mar 2011
    • 299
    • France
    Re: Two different graphics cards with continuity between the PCI-E connector pins
    Bump !
    • mariushm
      • May 2011
      • 3799
      Get an adjustable power supply, set it to a low voltage and limit current to 0.5-1a or so ... plug it in and see what gets hotter?
      There was another method, if you have a high count multimeter, you could actually measure the resistance gradually and when resistance changes you know where the short is
      See http://www.youtube.com/watch?v=JAOV_erLpYw
      • SuperDuty
        • Mar 2011
        • 299
        • France
        Thanks, it's going to be a tough one with my tools. I don't have an adjustable power supply. I'll go check if I can make one with a spare ATX PSU.
        As for checking manually with a multimeter, I doubt mine is precise enough for that kind of low resistance values.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          Most likely shorted MOSFETs in the VRM. If you don't have the tools to test, you'll just have to pull all of 'em off and see which one is short.
          A working TV? How boring!
          • SuperDuty
            • Mar 2011
            • 299
            • France
            Well I followed your advice and I've rechecked all the mosfets again...
            On the 9600GT, I HAD replaced a shorted mosfet prior to creating this thread, and I was surprised it didn't change the issue. Happened I had replaced a bad mosfet with...another bad mosfet. I guess I had damaged it when soldering. Once removed, the card displayed a nice boot screen ^^
            As for the HD4850, I did the same and...found a bad mosfet. I had checked them all though, but I think I just used the "beeper" of the multimeter. This time I READ what was written and found one was showing about a hundread ohms where the others next to it were showing no continuity. I removed it, plugged the card in and again, perfect boot up screen
            Thanks guys !
            So it makes four cards out of six from my last lot of dead cards that have been revived, the HD5750 works but the memory is faulty, I would need a BGA station to repair that, and the HD6770 won't do a thing. The GPU doesn't even heat up. The fan spins but that's it.
              master hoarder
              • May 2008
              • 12175
              Check GPU core voltage and RAM voltage. Post some pictures of the bare board (i.e. heat sink removed) so we can see layout.
              • corrize
                Where to find a very small fpc connector 0.3mm between 2 pins ?
                by corrize
                Hello, I search this connector (oxydated).
                It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                Do you know how to find this connector please ? What is the exact name for find it ?
                08-06-2024, 05:25 PM
              • pandrew
                Thinkpad T490 doesn't detect NVME
                by pandrew
                I have a Thinkpad T490 (NM-B901 Rev 1.0) that cannot detect an NVME M.2 SSD,
                but it works fine with a SATA M.2 SSD.
                When connecting an NVME M.2 SSD I get while booting:
                "2101: Detection error on HDD0 (Main HDD)"
                I can continue and boot a live linux distro from a USB stick, but it doesn't show up in lspci,
                and I don't notice any relevant error messages in dmesg.
                I have tried two different M.2 NVME SSDs (both working fine on a different machine),
                and the behavior is the same.
                I am pretty sure that all the important...
                11-13-2023, 03:04 PM
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • bussincaps
                MacBook Pro Mid-2014 A1398 Retina LED Controller Connector [First Repair (Disaster)]
                by bussincaps
                Hello All,
                tl;dr: minimal electronics experience and my first repair, lifted 8 pads off the laptop display LED controller board when attempting a connector replacement, options are attempting pad repair or jump wiring.
                Laptop Model: MacBook Pro 15 Mid-2014 Retina, A1398 MGXA2LL/A
                eDP Display: Samsung LSN154YL01-A02, assembly sold as Apple part 661-8310
                Soldering Equipment: Hakko FX-888D w/ T-18 tips (Chisel, Conical, Bevel types)
                I needed to replace the 30-pin I-PEX Cabline connector (labeled J8300 in the Apple 820-3662 mainboard schematics),...
                08-03-2023, 12:57 PM
              • Goblin999
                RX 5700 Red Devil PCIe pins help
                by Goblin999
                Hey guys . Just purchased a 5700 Red Devil with shorted pcie pins(12v + gnd I presume) . You can see the damage in the picture attached . Can anyone who has a working one point me where they go ? I know the first 3 pins are 12v power supply and the next one is GND , but I have no clue where the 5th pin should be going and I cannot find a board view anywhere . Any help will be much appreciated as I am trying to restore the pins and see where it gets me . Cheers...
                03-03-2022, 12:19 PM
