MS-6330 Ver2.1
    MS-6330 Ver2.1
    hi everyone
    ive got a MS-6330 Ver 2.1 that is missing 3 capacitors next to the power plug up the top marked C404 , C405 , C406.
    would i be safe to put 3 x 1500UF 10v ones in or would i be best off putting 1600uf 12v?
    the motherboard came from a gateway machine
    Re: MS-6330 Ver2.1
    here is a pic of ver3
    https://www.badcaps.net/forum/showthread.php?t=755
    is it similar?
    show which caps are missing and what values are already on the board.
    did someone remove the caps? or are they missing from new?
    you can use 10v
    there is probably no cap available with value 1600 12v.
      Re: MS-6330 Ver2.1
      I also have the same board with 3 bad caps same location they are 1500uf 10v I have some 2200uf 10v wondering if they will work the caps to be used are chmec getting rid of all chhsi caps I have some of the exact value caps and already replaced those
        Re: MS-6330 Ver2.1
        looking @ all caps you'll find7 1000uf 6.3v if your board has all the original caps the 3 up by the atx connector will be 1500uf 10vand you'll also have 4 470uf 16vthen the board has 5 kze 4700uf 6.3v btw all previos caps are chhsi good thing is the board does have another usb header you can add.
        Last edited by MichaelaE; 11-08-2006, 03:33 AM. Reason: posted a wrong value for a cap
