Msi pm8m3-v
  • tmiha71
    • Apr 2010
    • 130
    Re: Msi pm8m3-v
    I did not skip on the tin, as you can see, trying to lower every possible mOhms out...
    If you did not use silver or copper based solder -> bad joke
    • trodas
      • Jan 2006
      • 770
      • Czech republic
      Re: Msi pm8m3-v
      RJARRRPCGP -
      Careful! Some of their AM3+ boards are a joke! Where they can fail at more than a 25-to-50 percent load!
      Oh, really? That bad? What fail on them? The CPU VRM?
      tmiha71 -
      If you did not use silver or copper based solder...
      No, OTOH, that is good and valid suggestion. If cou could provide some solder based solder, then please drop me PM, I will supply you with my address where to send it. Every mOhm counts!
      "It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
      "I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway my config - my caps
      • tmiha71
        • Apr 2010
        • 130
        Re: Msi pm8m3-v
        For desoldering, and I repeat only for desoldering, I use one on the picture
        • trodas
          • Jan 2006
          • 770
          • Czech republic
          Re: Msi pm8m3-v
          For desoldering this will do fine, I quess. But I need something with the silver for the soldering ))
          • tmiha71
            • Apr 2010
            • 130
            Re: Msi pm8m3-v
            For soldering, on every place where current is higher than 0.5A (the only place in PC where current is less than 0.5A is USB :-))...
            Could not decide what is better, silver, or copper, got some mixed info, so got mixture of both...
            Soldering with this is a real pain...
            Sometimes use this tin for desoldering too, but, only, after the upper tin does not work :-))...
            Question about those LE poly's...
            Do you have information about self-resonant frequency ?
            What size are they 8x9 or 8x12 ?
            • kaboom
              "Oh, Grouchy!"
              • Jan 2011
              • 2507
              Re: Msi pm8m3-v
              No. Let's see- audio, video, signal (data, RAM, control) busses, IDE/SATA, serial/parallel/PS2 ports. Pretty much everything is less than half an amp except the various power traces and buck converters.
              Especially after mixing multiple solders on/in a single joint.
              Irrelevant.
              Use 60/40 or 63/37.
              "pokemon go... to hell!"
              EOL it...
              All style and no substance.
              guilty,guilty,guilty,guilty!
              guilty of being cheap-made!
              • tmiha71
                • Apr 2010
                • 130
                #27
                Re: Msi pm8m3-v
                don't do that , they almost never fail...
                Lil lead don't hurt, as long as there's silver and copper with that
                Irrelevant.
                Regarding self resonant frequency, not so. Stumbled on info that for poly's ESL (equivalent serial inductance) is case dependent and fixed /not related to capacitance/ (in same family). Smallest case (8x8) offers smallest ESL -> higher self resonant frequency -> better reaction on transient ->also absorbs transients of higher frequency...
                Also smaller capacitance -> higher self resonant frequency -> better reaction to transients...
                I like manufacturers with detailed info of their products...
                • ant3202
                  • Jun 2006
                  • 275
                  • Singapore
                  #28
                  Re: Msi pm8m3-v
                  Originally posted by trodas
                  So this obviously cannot stays like that, because the mobo is starting to shown first unstability issues and crash on load, so, there had to be recap. I also wanted badly to give the mobo back the nice polymers, the MSI marketing striped it off... In short, I wanted to trumph out the advert Because even better that Sanyo Oscon polymers exist - and that are Nichicon LE polymers. So I made my list of ideas, how the recap shuld look like:
                  9x Nichicon LE 820uF 2.5V d8 493-3058-ND
                  2x Nichicon HZ 3300uF 6.3V d10 UHZ0J332MPM-ND
                  4x Nichicon HZ 1000uF 16V d8 UHZ1C102MPM6-ND
                  16x Nichicon HM 1000uF 6.3V d8 UHM0J102MPD-ND
                  2x Nichicon LE 470uF 6.3V d8 493-3066-ND
                  1x Taiyo Yuden 47uF 6.3V 587-3406-1-ND
                  However certain things go wrong. The first was, that I managed thru friend to order only the original number of the 1000uF 6.3V caps, 12 of them. I had to improvise and replace the remaining 4 unused before with the Samxon GC caps, witch is similar is quality, tested good caps.
                  At lest I see what caps are new there, lol.
                  However worser was, that the only one d8 caps for 16V was really hi-end elytes Nichicon HZ, but they are out of the stock for months. So, what to do? I had no chance but to press on and thy some improvisation there...
                  And at last I completely forget the little SMD cap behind the AGP slot, witch I indented to replace with ceramic caps, when there is available even 47uF ceramic SMD caps with the little 12210 size!
                  So the main idea was to get the Vcore voltage filtering on hi-quality level, witch I managed easily by using the best polymers ever produced (nothing beat their ripple current rattings):
                  But now what to do with the input caps, that are not stock? In the end I managed to squeeze easily in their places (luckily, there is nothing upclose near them) replacement caps, witch I took from my stash - a Panasonic FM 1000uF 16V d10:
                  Of course I added even the unused one, right after the input coil:
                  Ram's get a quality Nichicon caps too now, so they cannot complain on discrimination changes:
                  What I also did miss is the sad look of six empty places, where a good quality ceramic caps should be, so the Vcore will be stable even in extreme situations:
                  As I mentioned, on the previously unused places I slap the Samxon GC caps:
                  And the NIC controller must be jumping out of joy, because it got the quality Nichicon LE polymers voltage filtering instead of the G-Luxon crap caps - now this is a jump in quality!
                  Over on the CPU socket, there come together two important caps. A Nichicon HZ - the best electrolyte caps ever when come to the ripple current (Samxon GA are par to par with it, but nothing other come even close, not even Rubycon MCZ, yet the Man Yue stoped manufacturing them ) and then the Nichicon LE - best polymer ever made:
                  And at last - overal look on the Vcore regulation - now it look far much better that before!
                  And the result? Well, the CPU and rams and HDD is working perfectly. The Vcore regulators, with the serious heatsinks, are - even that no fan is blowing at them, yet I removed the serial and parallel ports to get them better ventilated - after a day of work, night of stress test and half day of gaming heardly even warm...!
                  That well shown the fact, that quality caps means lesser temperatures of the components. That was just great. And with stock box fan and no case fan...!
                  Now just the AGP cap and some of these ceramics...
                  oh well... they are so sexy now
                  • tioklou
                    • Jan 2014
                    • 8
                    • Greece
                    #29
                    Re: Msi pm8m3-v
                    Hello and nice to meet you in badcaps forum! i want to ask if the board works better now with the 7x820uf poly's on the vrm because the overall capacitance now is a lot higher than before with the 3x680uf OST!
                    • trodas
                      • Jan 2006
                      • 770
                      • Czech republic
                      #30
                      Re: Msi pm8m3-v
                      Definitively much better It run very cool (the VRM part) and entierly stable (except AGP problems, but that is another issue) ...
                      Definitively a great improvement. But I would be still adding the ceramics and replacing the huge tantal-ceramic cap too. Just to make the board CPU VRM as clean, as possible
                      • tioklou
                        • Jan 2014
                        • 8
                        • Greece
                        #31
                        Re: Msi pm8m3-v
                        what did you believe cause the agp problem? capacitors or some mosfet problem?
                        • trodas
                          • Jan 2006
                          • 770
                          • Czech republic
                          #32
                          Re: Msi pm8m3-v
                          I replaced all the caps. So it must be either mosfet or connector problem. Not replaced the mosfets yet, simply stoped playing 3D games (hard to do on R9100 anyway) and that fixed it perfectly.
                          Played a 2D intensive game Diablo 2 for weeks and no crash. Even with the Glide wrapper, that stretch the 800x600 to 1280x1024....
                          So it is very stable, even using a P4 at 3.4GHz... w/o added better caps into the socket and around it yet. It shoudl be done, but I just did not get around to it yet.
                          • Dan81
                            SNES-powered
                            • Oct 2013
                            • 1866
                            • Romania
                            #33
                            Re: Msi pm8m3-v
                            Nice to see that someone is using a P4M800 chipset-based PC.
                            I have one too,however mine is s478.
                            Anyways,why don't you try Windows Vista on that PM8M3-V? It runs pretty fast. (at least for me)
                            Main rig:
                            Gigabyte B75M-D3H
                            Core i5-3470 3.60GHz
                            16GB DDR3-1600
                            Samsung SH-224AB DVD-RW
                            Delux MG760 case
                            • trodas
                              • Jan 2006
                              • 770
                              • Czech republic
                              #34
                              Re: Msi pm8m3-v
                              Windows Vista have too high memory requirments and compared to XP it is slow and locking me from modifying it, so Vista is a big NO-NO for me. Not even Win7 I like, on my NTB I started using Ubuntu - locking me also like Vista/Win7, but still there are modifications possible and it is interesting system.
                              BTW, still not get around to finish on the CPU VRM and replacing rest of the mosfets for the Northbridge/AGP.
                              • c_hegge
                                • Sep 2009
                                • 5219
                                Re: Msi pm8m3-v
                                Vista and 7 are both so slow that they are almost completely unusable on anything less than a C2D with 2GB RAM. The PC has to be a Core i3 with an SSD before I would consider it to be fast.
                                • eryjus
                                  by eryjus
                                  05-10-2023, 11:21 AM
                                • Paxman_Swede
                                  by Paxman_Swede
                                  Hello!
                                  01-14-2025, 09:51 AM
                                  by momaka
                                  03-12-2025, 03:42 PM
                                • captain150
                                  by captain150
                                  03-16-2025, 07:34 PM
                                • Foetuss
                                  Gigabyte GA-6OXT :: caps question
                                  by Foetuss
                                  Good evening
                                  I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                                  Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                                  But I was also suprised about the bigger boys, which are 330µF 25V.
                                  Could it be they used 25V caps because they were cheaper / available at that time?...
                                  02-11-2025, 12:22 PM
