ECS K7SOM+ On-board Processor burned
  • stng
    • Jul 2006
    • 34
    Recently got myself a ECS K7SOM+ after checking and found that
    the processor burned and causing short on VRM circuit ..
    Thinking to removed the burned processor and fixed with
    ZIF socket ..anyone can tell me how to do it ?
    INTEL CORE2DUO E6600 LGA775 + Cooler Master Hyper L3
    Asus P5W DH Deluxe (Wireless edition)
    2Gb Kingston DDR2 800
    Asus Xtreme N7600gs 256Mb Silencer PCI-E
    80Gb WD 7200 SATA + 40Gb Maxtor 7200 x 2 +
    80 Gb Seagate 3.5'' external HDD
    HL-DT-ST DVD rom GDR8163B
    HL-DT-ST DVD Ram GSA-4167B
    20'' Dell FPM LCD
    Cooler Master Centurion 5 + Acbel 450w with Active PFC
    Philips A2.610 5.1 speaker +
    Altec Lensing AHS30
  • Rainbow
    • Aug 2005
    • 1375
    Re: ECS K7SOM+ On-board Processor burned
    Maybe using a heatgun to remove the bad CPU, then get a ZIF socket (again using a heatgun on a dead board). The most time consuming part would be cleaning all the holes and then soldering the socket in.
    • MD Willington
      • Sep 2004
      • 702
      Find a used socketed board and recap it...
      Here it is in a nutshell...
      PcChips M810D / ECS K7SOM
      PcChips M810D 5.2A / ECS K7SOM+ V5.2A Thoroughbred XP 2400+
      PcChips M810D 7.5A / ECS K7SOM+ 7.5A Thoroughbred XP 2600+ (266 version)
      PcChips M810D 7.5C / K7SOM+ 7.5C CANNOT upgrade, embedded cpu.
      NOTE: PCChips M810D / ECS K7SOM+ : Remove C453 for XP support.
      MD
      Ya'll think us folk from the country's real funny-like, dontcha?
      The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
      • stng
        • Jul 2006
        • 34
        yup,u r write ..but the problem is i don't have access to heatgun..possible
        to use sucker to removed one by one of the pin ?
        20'' Dell FPM LCD
        Altec Lensing AHS30
        • stng
          • Jul 2006
          • 34
          MD
          There's nothing wrong with the cap i guess..
          20'' Dell FPM LCD
          Altec Lensing AHS30
          • arneson
            • Sep 2005
            • 1267
            I think I see where MD is going with this.
            The frustration and failure factor with removing a CPU and inserting a socket is way more than finding a board like yours with a socket and putting in all good capacitors
            for stability.
            Jim
            • stng
              • Jul 2006
              • 34
              for stability.
              Anyway gonna give it a try and update the status
              later ..if it worked out..
              20'' Dell FPM LCD
              Altec Lensing AHS30
              • MD Willington
                • Sep 2004
                • 702
                for stability.
                Exactly... there are MILLIONS of those boards around. The ones with the embedded CPU are a real pain...
                But I also understand the pride in the ability to repair something with your own hands and skills...
                I can say "good luck" with your project!
                • yanz
                  • Nov 2004
                  • 910
                  Yup, if you manage to successfully do it, your name will be included to the hall of fame /jk
                  It is pretty much impossible if you don't have some proper equipment.
                  Circuit Board Rework and Repair -> http://www.circuittechctr.com/index.shtml
                  not... yet. OST and GLuxon <-
                  • arneson
                    • Sep 2005
                    • 1267
                    Thank you Yanz, This was the xray view I was searching for a year ago.
                    It helps to explain how thru hole clean out is a delicate procedure and how unseen things can be wrong with a ground plain.
                    You are the est.
                    Jim
                    • yanz
                      • Nov 2004
                      • 910
                      nothing really, i linked the link that already linked here, somewhere... you're welcome btw
                      • stng
                        • Jul 2006
                        • 34
                        Have the burned processor removed by slowly knocked the processor in pieces then
                        removed the pin one by one ..now is trying to fixed the zif socket ..
                        20'' Dell FPM LCD
                        Altec Lensing AHS30
                        • Big Pope
                          Approved Vendor
                          • Dec 2005
                          • 426
                          Removal the on board CPU with a hot air gun. You may get some surprising from the dead of these kind of mothboards.
                          My SAMXON Capacitors Database HERE!!
                          X-CON is a new brand for SAMXON's Polymer Capacitors.
                          • stng
                            • Jul 2006
                            • 34
                            Ok done with the ZIF socket ..when fired up,it just won't POST but the fan is spinning
                            so guys any idea ?
                            20'' Dell FPM LCD
                            Altec Lensing AHS30
                            • Rainbow
                              • Aug 2005
                              • 1375
                              Is VCore OK? Are all solder joints good and no broken traces?
                              • kc8adu
                                • Nov 2003
                                • 8832
                                • U.S.A!
                                it likely has a vrm problem.
                                look for shorted mosfets.
                                bad news...it may kill every cpu you have tried!
                                • arneson
                                  • Sep 2005
                                  • 1267
                                  Done with the ZIF socket?
                                  Please back up a bit. How in the name of all that has pins on it did you get a line up and set down of the socket.
                                  What was your method? heat source?
                                  I read up on the manufacturing process for these, and they use an electron microscope and xrays to check the joints.
                                  Please share your technique.
                                  Jim
                                  • Rainbow
                                    • Aug 2005
                                    • 1375
                                    I don't think it's hard to solder. If the holes are clean (cleaning is probably the biggest problem) and the socket pins straight (not a problem when removed from another board using heatgun), you just put it in and solder the pins one-by-one.
                                    • arneson
                                      • Sep 2005
                                      • 1267
                                      Sorry,
                                      Guess I better shut up.
                                      The board I thought about doing this to was surface mount proc and socket, so I was thinking small pads, heat and compression.
                                      Jim
                                      • Rainbow
                                        • Aug 2005
                                        • 1375
                                        Many P4 boards have SMD socket - that's really a problem.
