GeForce 8600 GT bad caps
  • Julian Sivertsen
    • Norway
    I've got a 8600 GT graphics card from XFX with 7 blown caps. I believe they explain the pop sound I've heard a few time near the PC that I just couldn't figure out where it came from. Given that the board is from a reputable manufacturer I think it is heat that have killed the caps (the cabinet is WTF in air circulation), but I'm not sure. I'll post an image of it later as I don't have my camera here and I don't like the crappy images I get off my phone.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: GeForce 8600 GT bad caps
    let me guess fz caps.
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      Probably, XFX loved using FZ on the 8000 series
      • Julian Sivertsen
        • Norway
        Yes indeed it looks like FZ caps. I'm not familiar with the markings on the caps, but they are marked with it. I guess name does not really mean anything these days. I'll have to buy a soldering iron to actually replace them, so it may take awhile.
        • mariushm
          • May 2011
          • 3799
          Yeah, Sacon FZ series, awful capacitors from an awful manufacturer.
          You have three different capacitors on the board that are most likely bad:
          470uF 16v x3 pcs
          1500uF 6.3v x3 pcs
          1000uF 6.3v x1 pcs
          There's also an 1200uF 4v capacitor, that's made by a good manufacturer and it's actually polymer so it's unlikely to be bad.
          The 2 330uF 16v capacitors are made by OS-CON, which is OK I guess, I don't think those capacitors are bad.
          Anyway, suitable replacements would be Panasonic FR, FM, Nichicon HM, HN, Nippon Chemi Con KY, KZE, KZH, Rubycon ZLK and other from ZL*...:
          I'm giving you some links from Farnell Norway site, but if the shipping fees are too much there's also rs-online.com or others.
          470uF 16v:
          http://no.farnell.com/panasonic/eeuf...0uf/dp/1800634
          http://no.farnell.com/panasonic/eeuf...16v/dp/1219462 8x15mm
          http://no.farnell.com/panasonic/eeuf...0uf/dp/1848384
          http://no.farnell.com/rubycon/16zlk4...0uf/dp/1831283
          1500uF 6.3v
          http://no.farnell.com/panasonic/eeuf...0uf/dp/1800608
          http://no.farnell.com/nichicon/uhm0j...ial/dp/2113080
          http://no.farnell.com/panasonic/eeuf...-3v/dp/1219448
          1000uF 6.3v
          http://no.farnell.com/panasonic/eeuf...-3v/dp/1219447
          http://no.farnell.com/panasonic/eeuf...0uf/dp/2217555
          If you have to order a minimum of 5 pieces of 1500uF, then you could probably use one instead of the 1000uF capacitor.
          Also, if you can't find 1000uF 6.3v or 1500uF 6.3v at some other store from these brands and series, you can try searching for the same capacity but with a 10v rating, it will work just as well but the capacitors will be slightly bigger in dimensions so just make sure they would fit on the board.
          Or you could do it on purpose to save money.
          For example, that Panasonic FM 1000uF 6.3v is kr 3.98 while the following Panasonic FR 1000uF 10v is kr 2.02 - the specs are about the same, the FR is however a bit taller and thinner (which doesn't seem to be an issue with your card):
          http://no.farnell.com/panasonic/eeuf...0uf/dp/1800622
            NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
            The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
            10-02-2024, 08:52 AM
            EVGA e-GeForce 7600 GS AGP 256MD2 [256-A8-N542-T2] with bad caps - fixed
            by momaka
            I did it again – I had to fulfill my inner desire to fix yet another old piece of hardware. This one is actually kind of worthwhile, too – it’s an EVGA e-GeForce 7600 GS AGP video card, model P/N: 256-A8-N542-T2. With the popularity of “retro” PCs from the Win9x to XP era going up, and the diminishing supply of decent AGP cards, it is expected their prices will go up. Or is it? I bought the this video card rather on the cheap side (~$9 USD shipped to my door), because the eBay seller listed it for parts or repair (and correctly noted the bad capacitors.)
            So, here is the...
            06-06-2020, 04:39 PM
            NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
            The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...
            10-02-2024, 07:51 AM
            by momaka
            03-12-2025, 03:42 PM
            NVIDIA GeForce GTX 950 / GTX 960 Schematic & Board View
            The GeForce GTX 950 was a mid-range graphics card by NVIDIA, launched on August 20th, 2015. Built on the 28 nm process, and based on the GM206 graphics processor, in its GM206-250-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 950. The GM206 graphics processor is an average sized chip with a die area of 228 mm² and 2,940 million transistors. Unlike the fully unlocked GeForce GTX 960, which uses the same GPU but has all 1024 shaders enabled, NVIDIA has disabled some shading...
            10-01-2024, 01:54 PM
