Asus P5KC
    Asus P5KC
    Hi there,
    I have this Asus P5KC motherboard which I really liked (when it was still working). I wish to repair it if there is the chance.
    Symptoms:
    PC starting but no display and not even posting.
    It suddenly restarts the computer. (When it was still booting up)
    When shutting the computer down, the power supply never turns off, one will have to turn it off manually. (When it was still booting up)
    Thanks.
    Re: Asus P5KC
    It could be that ASUS random death 'feature'.
      Re: Asus P5KC
      so there is nothing that one can do right?
        Re: Asus P5KC
        Have you tried another power supply or opened up the power supply to see if you have bad caps?
        --- begin sig file ---
        --- end sig file ---
          Re: Asus P5KC
          yes i did try 3 different psu's and the problem remained the same
            Re: Asus P5KC
            hold down firmly on nb and power on.repeat sb.bet it posts.
            bga strikes again.
            last 2 a reflow of nb and sb fixed them
              Re: Asus P5KC
              Nice board!
              And bad BGA is not likely with P35, IIRC. Not as likely as Nvidia northbridges and southbridges from word that I got.
              I wish I had a P5KC in nice condition.
              ASRock B550 PG Velocita
              Ryzen 9 "Vermeer" 5900X
              Sapphire Nitro+ Radeon RX 6750 XT
              eVGA Supernova G3 750W
              Alienware AW3423DWF OLED
                Re: Asus P5KC
                will try and keep you posted. That's why I want to fix it as it is (or was) a good board.
                I couldn't find an exact new one to buy it.
                  Re: Asus P5KC
                  This is a FET problem... Test the FETS (That is if yuo can desolder them) on the bottom left corner of the board. If they test OK, test the VRM FETS. Asus used underspec'd FETs on that generation of board...
                  Replace with FETs that have a higher amperage rating and a lower RDS on.
                  "We have offered them (the Arabs) a sensible way for so many years. But no, they wanted to fight. Fine! We gave them technology, the latest, the kind even Vietnam didn't have. They had double superiority in tanks and aircraft, triple in artillery, and in air defense and anti-tank weapons they had absolute supremacy. And what? Once again they were beaten. Once again they scrammed [sic]. Once again they screamed for us to come save them. Sadat woke me up in the middle of the night twice over the phone, 'Save me!' He demanded to send Soviet troops, and immediately! No! We are not going to fight for them."
                  -Leonid Brezhnev (On the Yom Kippur War)
                    Re: Asus P5KC
                    I have some experiances where a bad VGA can make the all system to be in trouble.
                    Edit: Other than that check the pins in the socket. (Get a magnifier glass too)
                      Re: Asus P5KC
                      bga strikes again.
                      i held down firmly both of them and problem persisted.
                        Re: Asus P5KC
                        How can I test the FETS with a meter? I'm not experienced.
                          Re: Asus P5KC
                          the vga should be fine as I use it on other PCs and they work fine
                            Re: Asus P5KC
                            One thing that I have to point out is that when trying to power the board on, it powers but no display. It then turns off and turns on again automatically and stays on with no display.
                            I have just noticed this now while doing a bench test.
                              Re: Asus P5KC
                              Well @matthmal if you are not experienced to do an actual repair of the electronics of this board.
                              Other than a one attempt for a Bios re-flash, there is nothing that you can do.
                              I am using on my system an ASUS P5QC which is a great board stable and all,
                              check this model as alternative if you get out for a second hand buy on ebay.
                                Re: Asus P5KC
                                although i'm not very experienced, i am always willing to learn. well I have been troubleshooting TVs and TFTs with the help of this forum
                                  Re: Asus P5KC
                                  it seems that I can't figure out which are the FETS of the board.... can someone help me please?
                                    Re: Asus P5KC
                                    Tried a different graphics card?!
                                    Also, is the motherboard making any beep sounds?
                                    Muh-soggy-knee
                                      Re: Asus P5KC
                                      Yes I tried it with another one. Nope there are no beeps
                                        Re: Asus P5KC
                                        The no-BIOS-screen-and-no-bleeps symptom ominously reminds me of when I accidentally crushed my T'bird 1.3 with the heatsink on October 13, 2002!
                                        (Because of how I got the heatsink on after coming back from the Keene, NH RadioShack for white heatsink paste.)
                                        (At least the Soyo board was fine, just had to drop the T'bird 900 back in. )
