My Sapphire Radeon 8500LE decided it was tired of one of its SMD capacitors, and decided to let it fall off the PCB while I was installing it in the computer today. Not having too much luck identifying the value, so I could use some help there. Hopefully I have a standard cap that will replace it - I can get a non-SMD cap to fit on the board.
SMD Capacitor Identification
Tags: None
Re: SMD Capacitor Identification
I was not very successful finding something locally to replace this thing - would appreciate some more advice. I managed to find the following new caps, after being completely misunderstood by the sales staff at two different places. Turns out "low ESR" is a language they don't speak.
Fuhjyyu TN series - 25v, 100uF
Yubright, unknown series - 16v, 100uF (the alternative at the same place was Gloria)
I grabbed two of each since they were cheap. I also found an old Rubycon 85 degree general purpose cap that will work in my parts box - 6.3v, 100uF.
So, my question now is, do I use one of the above, or wait for my next big Digikey order which could be months away when I can get something decent?Comment
Take the rubycon, if the fails or makes the system unstable order some non SMD caps from TC. Fuhjyyu and Gloria are noth worth the truble, as i don`t think they will survive any long.I have recently replaced some GSC from an GF4MX440 card, even there was no switching regulator both badcaps have bulged leading to minor crashes when playing 3 d games.Comment
Do the world a favor, KILL THE Fuhjyyu WITH FIRE!!!
(or just apply the rated DC voltage to it and watch it fail within 3 months)"The one who says it cannot be done should never interrupt the one who is doing it."Comment
by MORETTIGIANTitle:
Capacitor detached from PCB – RTX 2070 Super Founders Edition
Description:
During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
I did not notice it detaching, so I am unsure of its original location on the PCB.
Procedure performed:
- Removed backplate
- Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
- Reapplied thermal compound
- Reassembled card
Observed behavior after reassembly:
- GPU powers on and operates normally under...11 Photos -
by pcconnectDead PS5 CFI-1216A, only 12v present on the board EDM-033
Blown capacitor which is located 'under' HDMI Decoder IC on the other side of the board. Does anyone know what is the value of the capacitor, please? Pics included.
Thank you... -
Hi there,
Beginner's question, sorry to waste your time...
I'm not certain of the values for the capacitor highlighted (on the picture with the tape) as I am seeking a replacement. Am I correct, looking at the schematics) to think it is a 33 pico Farad (pf) 25 Volts? The size seems to be 0201 from what I can assess and when I try to source a replacement, I'm struggling to find one and it doesn't look like something common.
Any help or suggestion welcome. This is on an Asus FX506H Quanta NJJ DANJJMB1AA0 Rev 1A... -
by PrologHi people, I hope this is the correct spot to post this, I'm new to the forum.
I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
I hope these photos make it clear which component I am referring to:
(yes, the soldering is a bit botched from removing the blown one, I know)
I have found the board schematic (attached), but there does not seem to be a boardview available. I have never... -
by antyPanasonic capacitor identification...
- Loading...
