The old VP6, need a little help
  • smokinkane
    • Feb 2006
    • 22
    Ok, so I traded for what is suppose to be a working VP6, and it did for about 3 hours. I installed 2 p3 1ghz processors 768mb of ram and all was good. Now it will only boot with 1 processor installed, doesn't matter which processor I use or which socket on the board. So I got to looking at the caps, all are nichicon (so they have been replaced at one time or another) except the 4 behind the pararell port. They are still black jacksons, so do you think my booting issue could be from the jacksons, or maybe the nichicon's are bad (they don't show any signs of it). Thanks ahead of time.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: The old VP6, need a little help
    the ones you describe are the vrm input caps.change them.
    btw these boards are a bit more demanding of good power.double check the psu and clear cmos.
    • tiresias
      • Feb 2006
      • 489
      Originally posted by smokinkane
      Now it will only boot with 1 processor installed, doesn't matter which processor I use or which socket on the board..
      The fact that it works with either socket, but not both, could also result from inadequacy (or bad caps too), of the PSU.
      Could you tell us which power supply you're using?
      • smokinkane
        • Feb 2006
        • 22
        I have tried 4 different power supplies, antec 385w, enlight 300w, ocz modstream 450w, and a sparkle 250w. I recapped the 4 left over jacksons behind the parallel port this morning, no luck. I removed the cmos battery, and cleared the cmos, no luck. I also reflashed the bios, still no luck, is there any special setting in the bios for enabling 2 cpu's? Is there any thing else I can try? Thanks
        • arneson
          • Sep 2005
          • 1267
          I'll take a stab here,
          You believe board was previously recapped?
          If this is the case you may want to inspect each solder joint on bottom of caps.
          The machine working three hours then not, and board being maybe flexed both physically and mentally.. I mean thermally could cause this.
          Jim
          • smokinkane
            • Feb 2006
            • 22
            Yes this board has all nichicon caps, except for the 4 jacksons I replaced this morning. So I will check the solder joints again, to make sure. Anything else I can check?
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              does it not post or not boot?
              • smokinkane
                • Feb 2006
                • 22
                I figured it out, the heatsink fan combo I was using was to much for the sockets. It flexed the board to much, causing the failed boot. I went back to intel heatsinks and all it well. Man these little boards with 1ghz's p3's run windows media center really well.
                • Alex@
                  Fake Nichicons?
                  by Alex@
                  I have recently received some Nichicon LKS1J103MESB 10,000uf 63v capacitors. They felt very light when I picked the up so I decided to weigh them. On my admittedly cheap scales they weigh 46grams the spec sheet says they should be 59grams. I tried them on 3 sets of scales and the readings are the same. The seller says that he only buys from mouser and digikey.
                  Is it possible for them to be real Nichicons? I really want them to be genuine it would save much time and effort. I am recapping an old Audio Dynamics ca2000e amplifier (I know it is an obscure make but...
                  08-17-2021, 02:38 AM
                  HP Pavilion 590-p0051na Pavilion 590 2700 Specification for Upgrade or Repair
                  This specification for the HP Pavilion 590-p0051na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion 590-p0051na boardview and Pavilion 590-p0051na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                  09-12-2024, 02:20 PM
                  Thermal pad thickness for various laptop GPU / Graphics Cards
                  ASUS Dual RTX 2070 OC 8GB
                  ASUS ROG STRIX RTX 3080 OC
                  ASUS ROG STRIX RTX 3090
                  ASUS TUF Gaming RTX 3080 OC Edition
                  ASUS TUF GTX 1660 S-O6G GAMING
                  EVGA RTX 3060 Ti XC GAMING 8GB
                  EVGA RTX 3060 XC GAMING 12GB GDDR6
                  EVGA RTX 3080 FTW3 ULTRA GAMING
                  EVGA RTX 3080 TI FTW3 ULTRA GAMING
                  EVGA RTX 3090 XC3 ULTRA GAMING 24GB
                  Gainward RTX 2080 Phoenix GS Specs
                  Gainward RTX 3070 Phoenix 8GB
                  Gainward RTX 3080 Ti Phoenix
                  GIGABYTE AORUS RTX 3080 MASTER 10G
                  02-09-2024, 08:08 AM
                • spiros.p
                  replace nichicon HE series 2200mf 16v with vishay BC 136 SERIES 2200mf
                  by spiros.p
                  i have replace nichicon HE series 2200mf 16v with vishay BC 136 SERIES 2200mf.measuring the nichicons sean on meter 2550mf and zero esr.i measure and the new vishays and sean 2080mf and near zero esr that looks normal.the nichicons numbers is normal so far from label data?and what about vishay 136 any infos from other users here?
                  09-27-2021, 06:12 AM
                • Topcat
                  Topcat's Ultimate Pentium 4 Retro Gamer!
                  by Topcat
                  I'll open this build with the comment that the Pentium 4 processor was probably my least-favorite CPU; even in Xeons. Netburst processors were hot-running and quite unimpressive performers considering the high clock speeds....but they were capable to a certain extent.....and are now entering the peculiar era of 'retro-ness'.
                  With that said; I was given THIS LITTLE JEWEL last Friday....a gaming rig built on the very CPU I liked the least....but there were some interesting things in it to say the least....and I really don't have a really good P4 retro gamer in my fleet....so....hmmm...yea...lets...
                  03-07-2022, 08:20 PM
