After recently acquiring 12 scrap computers, most of which require recapping, interest has been renewed in this board that I acquired in late 2009. A friend of mine got two of them from his place of work. Neither of them boot at all. The only thing that happens is a single 'click' from the onboard speaker and that's it. I remember back then that I heard a very faint 'whistling' noise coming from the board. The row of Teapo capacitors next to the CPU are bulging, a dead giveaway. I've decided to replace all the larger sized caps as they are a collection of Teapo and Evercon. The smaller 10uF, 22uF, and 100uF Teapos will stay (SS series), or replace them too?
I found another reason today why these board don't work. A few of the large caps in the power supply area are loose. One pin of a few caps physically move in the hole! Hope the board hasn't been damaged.
The original specifications of the major caps are:
Teapo SC
1000uF
6.3v
670mA ripple
85mΩ ESR
8x15mm
Teapo SZ
1500uF
16v
2318mA ripple
16mΩ ESR
10x20mm
Evercon ME
1500uF
16v
?? ripple
?? mΩ ESR
10x20mm
I don't know what the ripple current and ESR are for the Evercons. I haven't been able to find the datasheet for the ME series.
I've been looking for suitable replacements. As I see it, the ripple current is more of a capability whereas the ESR is more of a characteristic. Therefore, I surmise that a ripple current greater than or equal to the original is recommended, but the ESR should be as closely matched as possible. Thus, a brief search yields the following results:
1000uF replacement:
Rubycon YXG 1000uF 87mΩ 840mA 6.3v 8x16mm
SamXon GT 1000uF 87mΩ 840mA 6.3v 8x16mm
1500uF replacement:
Rubycon MBZ 1500uF 13mΩ 2550mA 16v 10x20mm
Nichicon HM 1500uF 13mΩ 2550mA 16v 10x20mm
SamXon GD 1500uF 13mΩ 2550mA 16v 10x20mm
However, I've read that the MBZ series has been discontinued.
Also, while desoldering a few caps on one of the boards, I noticed this a few days later. What could it be? It seems to be spreading from the holes. I had been using flux, would that have caused this? Will it affect the board in the long run? It's not like the copper is lifting or anything. It's also on the top side.
Regards,
TheSolarShed
Teapo SC
1000uF
6.3v
670mA ripple
85mΩ ESR
8x15mm
Teapo SZ
1500uF
16v
2318mA ripple
16mΩ ESR
10x20mm
Evercon ME
1500uF
16v
?? ripple
?? mΩ ESR
10x20mm
1000uF replacement:
1500uF replacement:
Regards,
TheSolarShed
