Dead Asus board
  • cbrf4i2002
    • Feb 2012
    Dead Asus board
    Okay hi everyone my Asus dead as door nail... need help.. popped den nothing works no light no nothing .. zilch
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Dead Asus board
    Moved from the member introduction thread.
    sounds like another case of SADS (sudden asus death syndrome)
    a model number would really help...
    sigpic
    (Insert witty quote here)
    • c_hegge
      • Sep 2009
      • 5219
      Re: Dead Asus board
      You say it popped. what part of the board went pop? can we have a few pictures?
      • iusar
        Asus PRIME B460M-A R2.0 - Absolutely Dead Board
        by iusar
        Hello.
        I'm working on an Asus PRIME B460M-A R2.0 that's completely dead. The Nuvoton NCT6798D Super I/O gets abnormally warm in standby.
        Need this boardview to measure Super I/O signals. Much appreciated!
        06-23-2025, 07:51 PM
      • k370
        Yoga3 Pro-1370 Board NM-A321 DEAD no power at all
        by k370
        I have a NM-A321 board that is dead, with no power at all.
        When I received the laptop, the +5VPMIC line was shorted. Removing the PU3 (ISL95905) solved the short, so I ordered and replaced the ISL.
        With the new ISL, the short is gone, but still no voltages at all. I measured the following rails:
        • +3VALW
        • +5VAUX
        • 1.2VSUS_PWRGD
        • 3VALW_PGD
        • 1.05VAUX_PWRGD
        Additionally, the ISL95906 (PU3) is not getting any voltage on the VIN rail.
        The only place on the board where I find any voltage is on the first MOSFETs, specifically:...
        09-23-2024, 11:57 AM
      • DynaxSC
        ASUS STRIX Z490-F GAMING - No POST, stubborn board
        by DynaxSC
        I have this very stubborn ASUS mobo on the bench, and I already face the wall with it. It just refuses to POST, although everything seems to be OK.
        The situation looks like this:
        After connecting the board to the power supply on Nuvoton (SLP_S3#, pin 64), the Low signal (50 ohm resistance) appears immediately. PWRNTN# signal goes through Nuvoton to the chipset (confirmed after removing the chipset). The following conditions are then met for the chipset to generate the SLP_S3# signal:
        1. RTC oscillates normally (32.768KHz).
        07-08-2022, 05:45 AM
      • jimbodriver
        Faulty ASUS X99-PRO board. Some progress with repair. Need advice\help please.
        by jimbodriver
        I am trying to learn electronics repair. I purchased a “faulty for spares/repairs” ASUS X99-PRO/ USB 3.1 motherboard for a very low price from ebay – a good enough price to offset the high probability that the board was completely toast and not realistically repairable.
        Initial results:
        Board would power-cycle when turned on either with switch on board or shorting pwr pins. Fan would spin for a second or so and a QCODE of 00 would display then it would power off and then do the same thing again over and over. I think maybe 2 times in about 100 attempts...
        03-20-2022, 02:30 PM
