Okay hi everyone my Asus dead as door nail... need help.. popped den nothing works no light no nothing .. zilch
Dead Asus board
Tags: None
Re: Dead Asus board
Moved from the member introduction thread.
sounds like another case of SADS (sudden asus death syndrome)
a model number would really help...sigpic
(Insert witty quote here) -
Re: Dead Asus board
You say it popped. what part of the board went pop? can we have a few pictures?I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
Assuming...7 Photos -
by iusarHello.
I'm working on an Asus PRIME B460M-A R2.0 that's completely dead. The Nuvoton NCT6798D Super I/O gets abnormally warm in standby.
Need this boardview to measure Super I/O signals. Much appreciated!-
06-23-2025, 07:51 PM -
by k370Hi everyone,
I have a NM-A321 board that is dead, with no power at all.
When I received the laptop, the +5VPMIC line was shorted. Removing the PU3 (ISL95905) solved the short, so I ordered and replaced the ISL.
With the new ISL, the short is gone, but still no voltages at all. I measured the following rails:- +3VALW
- +5VAUX
- 1.2VSUS_PWRGD
- 3VALW_PGD
- 1.05VAUX_PWRGD
Additionally, the ISL95906 (PU3) is not getting any voltage on the VIN rail.
The only place on the board where I find any voltage is on the first MOSFETs, specifically:... -
by DynaxSCHi,
I have this very stubborn ASUS mobo on the bench, and I already face the wall with it. It just refuses to POST, although everything seems to be OK.
The situation looks like this:
After connecting the board to the power supply on Nuvoton (SLP_S3#, pin 64), the Low signal (50 ohm resistance) appears immediately. PWRNTN# signal goes through Nuvoton to the chipset (confirmed after removing the chipset). The following conditions are then met for the chipset to generate the SLP_S3# signal:
1. RTC oscillates normally (32.768KHz).
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
- Loading...
