Success story! ASRock K7VM4
  • Mr1AV
    • Dec 2011
    • 5
    Ok so I found a computer on the side of the road during a hard rubbish collection in the local area. Its an ASRock K7VM4 with AMD Athlon XP 2500+ (Barton core). It would boot OK sometimes, but other times it would present lovely BSOD. Furthermore it wouldn't post at all with 2GB of DDR 400 installed.
    I noticed the x3 caps around the CPU were partly expanded "KZG" brand. Got the Nichicons [edit] replacements from badcaps and proceeded with the removal and install. Went fine! First time doing a motherboard (practised a little on a junk one). Just had to ignore the circuit diagram printed on the board as the shaded side was NOT negative!
    System boots with no issue now, and I can install the 2GB of ram without issue.
  • mockingbird
    • Dec 2008
    • 5484
    Re: Success story! ASRock K7VM4
    Those are not Rubycon replacements you got, those are Nichicons. Also very good caps.
    • Mr1AV
      • Dec 2011
      • 5
      Thanks. Edited the correction
      • c_hegge
        • Sep 2009
        • 5219
        Looks good, although those other smaller caps could give you trouble in the near future.
        • mockingbird
          • Dec 2008
          • 5484
          I thought so too, though the board is too early to have KZJ, and the color is wrong for TMV/TMZ/TMJ (And too early for those too), and the color is wrong for any other UCC series. So I'm also curious what the small caps are.
          • Mr1AV
            • Dec 2011
            • 5
            It says "TMZ" on all the small ones..
            • mockingbird
              • Dec 2008
              • 5484
              Mr1AV - you need to replace those too.
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                I've come across TMZ dated July 2003.
                Mann-Made Global Warming.
                - Dr Seuss
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Yes
                  - Dr Seuss
                  • shovenose
                    Send Doge Memes
                    • Aug 2010
                    • 6575
                    Nice job! Looks better than my soldering
                    • Mr1AV
                      • Dec 2011
                      • 5
                      Are the TMZ caps known for failing with bulging tops or going bad without physically showing? All 11 of these are 6.3V 1000uF.
                      What would be the ideal series replacement?
                      There are also x4 "KZE" 1500uF. Are these a bad series too?
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        • Romania
                        KZE are good. I've actually used them to replace KZG and they work okay.
                        A working TV? How boring!
                        • c_hegge
                          • Sep 2009
                          • 5219
                          TMZ, KZG, and KZE are all made by Nippon Chemi-con. They are a good japanese manufacturer, but have problems with the KZG, KZJ and TM_ series. KZE, KY and the others are all fine. To rplace them TMZ caps, use https://www.badcaps.net/store/produc...roducts_id=165 (Nichicon HN)
                          • Mr1AV
                            • Dec 2011
                            • 5
                            Thanks for that info! I'm sure I will get round to replacing those caps soon.
                            There is still some issue with two sticks of 1GB DDR400 on the mobo (max capacity). Even swapping the sticks around from DIMM 1 and DIMM 2 causes an issue "PFN list corrupt" blue screen after about 15 mins. Running either dimm alone works fine (1GB). It seems there were other issues with these boards and memory compatibility so i guess i'll find out if its caps or bios in due course.
                            I'm trying to find a suitable place locally in Australia and found RS components http://australia.rs-online.com/web/
                            I'm not sure which is best in the 6.3V 1000uF range:
                            Panasonic FM: http://australia.rs-online.com/web/p/aluminium/5260932/
                            Panasonic FK: http://australia.rs-online.com/web/p/aluminium/0571117/
                            Nichicon HE: http://australia.rs-online.com/web/p/aluminium/4909462/
                            Nichicon UPA0J102MPD: http://australia.rs-online.com/web/p/aluminium/0541706/
                            Rubycon YXF: http://australia.rs-online.com/web/p/aluminium/2244101/
                            Rubycon ZL: http://australia.rs-online.com/web/p/aluminium/7037208/
                            Is "Lifetime" the best indication when selecting the series?
                            Thanks for the assistance
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              The Lifetime you see isn't an estimate of the cap's lifetime.
                              The proper/full name is Endurance Lifetime. [Some call it Load Life.]
                              Basically it's how long you can abuse the snot out of it and -not- have anything go out of spec.
                              Might last 1 week or 25 years after the test. [They don't even guess.]
                              - IOW: Ignore the 'Lifetime'.
                              It's not useful info unless your application seriously stretches the cap's rating limits.
                              Other than Volts and uF
                              #1 = ESR [You want the same or lesss]
                              #2 = Ripple [You want the same or more.]
                              Remember the voltage rating is a limit on the cap, not a target circuit voltage.
                              Actual circuit voltage just has to be less than the cap's voltage limit.
                              TMZ has pretty low ESR.
                              Of those you listed FM is best choice to replace TMZ.
                              FR should also be good if they have some.
                              10v caps can also replace 6.3v caps just fine so that may give you more options.
                              ON MOTHERBOARDS.
                              6.3v caps can replace 10v caps too. [Works both ways.]
                              ~ The Mobo voltages are 12v or 5v or less.
                              ~ A 12v circuit would have cap's rated for 16v or more.
                              ~ Neither 6.3v nor 10v would be used on a 12v circuit.
                              That means if the original cap is either 6.3v or 10v then actual circuit voltage is 5v or less - so either 6.3v or 10v caps will work fine.
                              Other than this special case where we already know the voltages, don't lower an original cap's voltage unless you know [check] the voltage in the circuit.
                              - Dr Seuss
                              • c_hegge
                                • Sep 2009
                                • 5219
                                use http://au.element14.com/nichicon/uhm...10v/dp/1823803. RS don't have anything good enough to replace the TMZ. FM is the closest in that list, but Nichicon HM would be better again.
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  Agree that HM would be better. Or Sanyo [Suncon] WG or Rubycon MBZ.
                                  Based response on where OP was evidently looking to buy.
                                  If OP is stuck with RS then FM is the best choice.
                                  - Dr Seuss
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 4953
                                    • New Zealand
                                    Yes, you must watch out for that especially with devices from Asus and ASRock (A Spin-off from Asus)
                                    -David VanHorn
