Secondary MCP61PM-HM issue & my work-around
  • mazade
    Jack of Trades
    • Apr 2010
    • 40
    This will be the second MCP61PM-HM motherboard that I've received(deliberately) and recapped with good results... yet there is still an issue which seems to have lingered on one board, but perhaps both(will find out this week I hope).
    1. the System Fan plug is only putting out 5V on the + , not the 12V that it should be. Fan will not run, and system constantly gives the "System Fan Has Failed" message upon boot-up.
    2. CPU fan plug is not putting out full 12V either, but I have a harder time checking the actual voltage put out since the system will shut down if it receives no fan RPM signal on the CPU fan connector(i.e. unplugging connector to check voltage when motherboard is in the case). In this case though the CPU fan spins, but it is noticeably slow(enough to cause concern).
    My best guess, and yes that's all it comes down to, is that the nearby WM772L transistor/IC has somehow failed; both the CPU and System fan connectors get their + power through one of those chips(theres 2 of these chips total). Unfortunately I cannot come across any information(data sheets) on that chip number, not to mention finding a replacement.
    For the System Fan function I just nabbed 12V from a nearby surface mount resistor/fuse with the black markings on a white background "P" "150-24", and also made certain that the WM772L chip was no longer connected to the + power lead of the System Fan connector.
    I basically did the same thing for the CPU Fan connector, except this time I couldn't locate +12V on most things nearby, and thus I grabbed power direct from the 24-pin power supply input(pins 19 & 21 are good 12V pins). I ran a 20ga wire on the underside of the board between the supply input and the CPU Fan + input; also remembering to break the connection between the failing IC and the + input(nearby SMD resistor).
    Results: no "System Fan Has Failed" message, and the CPU Fan spins as fast as it should(IMHO - much faster than before).
    Now I just need to find out if this issue also is occurring on the first MCP61PM-HM that I re-capped.
    Pictures to follow.
    Also, I did mount a small 12V fan to the chipset heatsink, I do not trust this thing to run warm for too long considering all the potential fail issues of the Nvidia chipsets.... at least now that it's part of my collection
    Heheh, Legacy OS 2 live CD boots up just fine in with XVesa...
  • c_hegge
    • Sep 2009
    • 5219
    Re: Secondary MCP61PM-HM issue & my work-around
    That board temperature controls the fans, so 5V is perfectly normal.
    • mazade
      Jack of Trades
      • Apr 2010
      • 40
      Really? Well, why would the "system fan" not spin at all? It's a small crossflow fan, and the 5V that's being input doesn't even begin to turn it over...
      The CPU fan spun so weak that it would hardly move, and if it was stopped(by a finger or something) it wouldn't even start back up on its own.
      Perhaps you're right about that, but yikes!
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16956
        because you have the case fan plugged into the wrong header. Been there done that, I see these boards all the time.
        Yes, the fans are temp controlled. then spinning slow is perfectly normal. As the system heats up, the temp control spins the fans up faster.
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          You are using 3-wire fans with tach's,, right?
          Mann-Made Global Warming.
          - Dr Seuss
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16956
            Well that too...
            Team : 49813
            Join in!!
            Team Stats
            • c_hegge
              • Sep 2009
              • 5219
              Wait... A crossflow (hamster wheel) fan? that's not the original HP fan then. That might explain it. The HP fans usually rev really fast at 12V (5000+ RPM) and sound like jet engines. 5V spins them at around 700-800RPM.
              • mazade
                Jack of Trades
                • Apr 2010
                • 40
                I have this board out of its original case and all, just picked it up bare on ebay for cheap.
                OK... so I'm a dupe regarding their weird setup...
                I just dont like the thought of that thing being able to heat up, at all, especially with that sensitive Nvidia chipset that doesn't have any active cooling for it
                • rounin
                  MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                  by rounin
                  I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                  🛠 Original Issue
                  The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                  ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                  04-19-2025, 01:18 AM
                • ugamazing
                  Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                  by ugamazing
                  I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                  We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                  12-17-2024, 07:05 PM
                • elmark
                  HP 15-cw1002ua strange keyboard issue
                  by elmark
                  HP Pavilion 15-CW1002UA
                  S/N 5CD0251CBC
                  P/N 7KE54EA
                  Hello guys!
                  I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                  It powers on OK and has no other issues except the following:
                  • CAPS LOCK does not work at all
                  • Fn button toggles Flight Mode
                  • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                  • (with SHIFT pressed: 't%' and 'y^' respectively)
                  I initially thought it was a keyboard malfunction (internal short, etc.),
                  but when I press and hold...
                  06-27-2025, 01:10 AM
                • Simone Vergani
                  Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
                  by Simone Vergani
                  I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
                  To assist with troubleshooting, I'm attaching two power circuit schematics:
                  • Power
                  03-05-2025, 02:25 PM
                • wizard13
                  Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
                  by wizard13
                  I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
                  I have checked the forum and the available documentation but could not find a solution specific to my issue.
                  • Brand & Model: Dynabook Satellite Pro C50D-B-100
                  • Part Number (P/N): PYU13E-00C00PFR
                  • Serial Number (S/N): 22028896H
                  • System Configuration (SC): A1PYU13E1127
                  • Motherboard Model: IP3_ACN16_MB_V21_20211222A
                  • Power Input: DC 19V –
                  02-28-2025, 02:43 AM
