MSI 865PE Neo2-P - cannot install OS
  • Behemot
    • 4845
    • CZ
    Re: MSI 865PE Neo2-P - cannot install OS
    Just discovered the CPU I was talking about was different one, not this from the 85PE Neo2-P. Will swap them and try because this is 2,6 GHz Northwood with HT (800 MHz FSB) and the currently good one is just 2,4 GHz.
    • eccerr0r
      It's 2025: do you know where your 5¼" floppy drives are?
      by eccerr0r
      Oh wow.
      As in the other thread I was trying to revive/re-bootstrap an old Apple IIe and wasn't successful reading or writing any disk. Both drives behave similarly.
      Then I was wondering, what about my PC floppy drives? I have a HH 5¼" HD drive and a combo 5¼+3½ drive. I tried formatting the disk that wouldn't work in the Apple and it didn't work in the PC either!
      Then I tried a HD 5.25 disk ... it won't even touch the disk either! Just like the Apple DD disk, "Not Ready!"
      Weird. Seems the PC drive is having trouble clamping...
      07-07-2025, 12:49 AM
    • japlytic
      DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
      by japlytic
      In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
      Tried (only with keyboard/mouse connected):
      • BIOS + database update
      • Using latest Windows 11 image built with official image creation tool
      • Previous setup version for Windows 11 installer
      • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
      • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
      • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
      06-19-2025, 04:59 PM
    • 24gsm
      MacBook Pro A1708 install macos fail
      by 24gsm
      hi to all
      i have MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
      after enter to recovery and format hdd 1to .
      after try to install macos online . its frezz at loading install in boot and i waiting few hour but nothing i ty install by boot using flash disk but same issu
      can help please
      Serial Number: FVFXP0U0HV2J
      Config Code: HV2J
      Find My Mac: OFF
      04-16-2025, 03:57 AM
    • duwane
      A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
      by duwane
      Hi All.
      Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
      The issue:
      Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
      10-26-2022, 07:02 AM
    • tommy97
      ASUS FA507R - BLOD, cannot install windows
      by tommy97
      I have an ASUS FA507R in for repair where I’m unable to install any operating system. The laptop works fine when booted from an external Windows or Linux drive, but any attempt to install on an NVMe SSD fails.
      I’ve already tested with three different SSDs (Gen 3 and older), and the issue persists. The laptop originally came in with a faulty SSD showing 0% health....
      08-22-2025, 07:55 AM
