Asus P3v4X Mosfet Connection : Source to ground
  • supersabre
    • Feb 2006
    • 45
    I am trying to repair a asus P3V4X, now i pretty much finish everything except the mosfet.
    I 'm not sure whether the mosfet's source is connected ground or not(picture burn0.jpg point A and B)
    Let me know the resistance value if you have the same board
    the mosfet is near the cpu slot and the HIP 6013CB
  • linuxguru
    • Apr 2005
    • 1564
    Re: Asus P3v4X Mosfet Connection : Source to ground
    Most probably not - the source (B) connects to the cathode (tab) of the flywheel diode (D10?) and one side of inductor L14. The drain (tab) of the MOSFET is probably connected to the +5v or +12v rail.
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      Is the pic of your board? Because that chip (voltage controller chip?) has a burn mark...
      • supersabre
        • Feb 2006
        • 45
        the picture is taken before the repair. I have just replaced the hip6013cb chip . I just want to make sure the mosfet 's connection.
        • Scotchmist
          Asus GA502D keeps blowing mosfet
          by Scotchmist
          I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
          I have removed the mosfet and can run the laptop no problem
          The MOSFET is FDPC5018SG
          Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
          08-24-2024, 02:23 PM
        • MicroSMD Lab
          ASUS ROG Zephyrus GPU Mosfet repeat failure
          by MicroSMD Lab
          The board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
          I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
          01-10-2024, 06:36 AM
        • someonenotyou
          ASUS G513R - cannot remove MOSFET
          by someonenotyou
          Hi.
          I have a ASUS G513R laptop with shorted MOSFET (MP86959GMW-Z 45A).
          I tried to preheat the board to 200C brom the bottom and with rework station set to 400C I flowed it for about 2min. The MOSFET does not come off.
          Of course, I did not force it, but tried to lift it up with tweezers.
          Is it possible, that these MOSFETs are glues to the board? Or it got welded to the board from the short? It looks intact, no signs of blowing up.
          10-10-2025, 11:05 AM
        • Timp74
          Odd MOSFET only on some ASUS x99/x299/z370 motherboards..
          by Timp74
          Hi All,
          Could anyone comment on the purpose of the MOSFET circled in red in the attached photo of an ASUS ROG X299 Extreme VRM?
          I'm trying to fix an ASUS motherboard(WS x299 SAGE) with a similar VRM where this MOSFET has burnt out along with one of the IR3555m driver chips. From looking at photos of motherboard VRMs on the internet, it seems only some ASUS motherboards have a MOSFET like this. Although I've seen some photos of ASUS z370 boards where it's not populated. The MOSFET is usually a NTMFS4C06N. It has its drain connected to the output of the Vcore VRM, and on...
          08-13-2021, 01:11 PM
          ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook Specification for Upgrade or Repair
          This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
          09-07-2024, 02:50 AM
