GA-7VRX Cap Problem
  • ssmercurys
    • Feb 2004
    GA-7VRX Cap Problem
    Alright I went to work last night, I am a night owl and work overnights...but anyways my computer is almost always on and I came home from work but to no surprise my pc was off...I hit the power button and the CPU fan spun about 2 seconds and shut off..ok first thought power supply, nope tryed fine...second hdd and other periphials, took those out, nope fine...finally looked at capacitors about 2-3 were totally bulged and knocked off center (sorta leaning)
    hopefully Ill get a replacement from gigabyte but if not I guess ill be finally getting my new dream NForce2 Board now that I have a reason to... ^_^
  • BOCTOK
    • Mar 2004
    • 6
    Heeeyyyyy..... :roll:
    I never thought of it that way. Sorry honey, the board is shot....gotta get a new one...Dude, you are a genius!
    Actually, I'll try to re-cap mine before and if it works, just kind of lose it in the attic until a few months down the road.
    Athlon XP 2400+
    Gigabyte GA-7VRXP v1.1
    Radeon 9700 Pro
    Audigy 2 Platinum
    2x 80GB Maxtor HDDs
    512MB Micron PC2700
    Lite-on LTR48246S CDRW
    Sony DRU500AX DVDRW
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16959
      If Gigabyte's RMA's are anything like Abit's or Asus's, recap it yourself! That will definitely fix the board. Abit has sent me more bad boards through RMA's than I can even count.... Stretch received TWO bad VP6's from them this month alone!
      I'd try myself first, unless you absolutely just don't know how to solder... In which case, find someone to do it for you.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • BOCTOK
        • Mar 2004
        • 6
        Does anyone have a GOOD RMA system?
        Better to do it yourself, so you know what replacement caps are used. I don't think they will be using top of the line stuff through the RMA system.
        Athlon XP 2400+
        Radeon 9700 Pro
        Audigy 2 Platinum
        2x 80GB Maxtor HDDs
        512MB Micron PC2700
        Sony DRU500AX DVDRW
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          ssmercurys : best to research your new nforce2 board to see if the caps are from good manufacturers before you buy. It is disspointing to see some of the taiwan majors still using low quality cap manufacturers.
          • theone111
            by theone111
            3. Problem: TV shuts down
            07-22-2024, 10:36 AM
          • Zeonalbasta
            Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
            by Zeonalbasta
            i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
            The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
            09-13-2024, 01:17 PM
          • Gibon378
            Problem with stopping audio and video for no reason
            by Gibon378
            PC Specs:
            • CPU: Ryzen 5 1600
            • GPU: GTX 1080 Palit JetStream
            • MOBO: ASRock ab350 PRO4
            • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
            • PSU: XFX 650W (don't remember what model)
            • OS SSD: ADATA SP920
            • OS: Windows 10 21H2
            Problem description:
            Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
            11-19-2022, 09:41 AM
          • perzyk23
            Lenovo T580 - LCD Panel problem - error 0288
            by perzyk23
            Good morning,
            I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
            10-25-2024, 12:42 AM
          • lazaro.089
            Asus Zephyrus M16 / GU603ZW problem
            by lazaro.089
            Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
            CPU: Core i9-12900H
            Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
            Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
            The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
            08-26-2025, 06:33 PM
