12v DC - 240v AC Inverter / Battery charger failure
  • sliver
    • Sep 2010
    • 7
    The device currently works only as a battery charger, taking in 240v AC and outputting enough to charge a 12v DC battery. 3000 watt capacity.
    Reading the AC output in inverter mode with no load attached showed very small voltage fluctuating below 1 volt.
    I am thinking it might be capacitor related.
    • - The device makes a pulsing beep when in inverter mode
    • - Fuses look fine
    • - Fans (all 12v) functioning fine
    • - Some white gooo on one of the coil things
    Picture attached. Any help or pointers most appreciated.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: 12v DC - 240v AC Inverter / Battery charger failure
    i dont see the guts of a 3kw inverter there!looks cheap and nasty.
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      Can you take a picture of the whole board? I sure hope that transformer is for the battery charger, because if it's for the inverter it'll do 400W tops and that's with adequate cooling. Long stretch to 3kW from there.
      A working TV? How boring!
      • kaboom
        "Oh, Grouchy!"
        • Jan 2011
        • 2507
        400... on a good day... under oil.
        Real nice with that IC's marking sanded off.
        Did they actually think paralleling those diodes would increase their ampacity?? Device with lowest Vf hogging all the current comes to mind.
        "pokemon go... to hell!"
        EOL it...
        All style and no substance.
        guilty,guilty,guilty,guilty!
        guilty of being cheap-made!
        • lti
          • May 2011
          • 2548
          I thought that was incorrect as well, but that is common practice in many applications. However, I haven't seen anyone try to connect more than two diodes in parallel, and there are at least eight connected in parallel there with huge solder blobs between the leads.
          • japlytic
            • Oct 2005
            • 2086
            What brand is it?
            Soldering looks sloppy, and why were several diodes on the right used instead of a few higher power ones.
            In some cases, I can identify ICs by making a circuit with the surrounding components. It might be a TL494, who knows?
              NVDC charger configuration...
              11-05-2024, 03:28 PM
              ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
              Highly Integrated Narrow VDC Battery Charger for Notebook Computers
              The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
              for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
              Narrow VDC applications where the system power source is
              either the battery pack or the regulated output of the charger.
              This makes the max voltage to the system equal to the max
              battery voltage instead of the max adapter voltage. Operating
              at lower system voltage can improve...
              11-05-2024, 04:43 PM
              Milwaukee M18 HD12.0 (12 amp hour battery pack) unbalanced failure charger refusing
              by sam_sam_sam
              I have two Milwaukee 12 amp hours battery packs that have an issue with battery cells very unbalanced these are probably over 4 years old and been heavily used in the past but now get occasionally used heavily and when I went to use the grinder tool the battery lost battery battery power very quickly so I decided to open it up and found some battery cells voltage from 3.6 to 4.1 no wonder the battery charger was not fully charging them 3 out of 4 LEDs were on meaning that it was only 75% charged
              So I have put them on the battery testing machine to drain each battery cell down to...
              09-04-2022, 04:45 PM
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
              Bauer tool battery pack charging with a HERCULES charger modification
              by sam_sam_sam
              The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
              Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
              05-06-2023, 12:17 PM
