Hi there,
Looking for insight from you experienced gentlemen... I'm hoping I missed something.
Asus A8V Deluxe
For its owner the thing has become less and less reliable, powering off/freezing/dying becoming more common, it sounds like it has sat unused for 6 months to 1 year.
I get my hands on it and notice that it's loaded with KZG caps, like 20 of em;
6.3V/820uf things. So I get on here to learn, and then follow standard procedure. A bunch of Samxon 6.3V/820uF caps for most places, Fujitsu Poly 2.5V/820uF caps for Vcore, Samxon/Rubycon 6.3V/1500uF for some spots above Vcore, and Samxon/Rubycon 16V/1000uF for some more by Vcore & near to P4 power plugin.
The cap silkscreens on this board are reversed(at least that's what I'd think), with the positive half being whited out instead of negative... I checked stock setup, and also referred to pics of other members A8V recaps. I double/triple-check and everything is in as it should be.
I'm thinking things are sailing here.
Plug the board & accessories back in, power up...
The Caps Lock, Scroll Lock, and Num Lock are ALL flashing simultaneously, and continuously. The screen doesn't come on either. Dead End.
Things attempted:
Try less ram(single stick) and/or swapping out for other sticks
Swap out Video Card(had AGP, I try a known working PCI card)
No extra pci cards either.
Swapped out CPU
Swapped out Power Supply
Pulled board and tested all cap leads while board is powered up on shop bench, everything checks out, didn't miss or short anything that I can tell.
Purchased and swapped in a new bios chip.
This is not a Nvidia Chipset
I'm only posting because I've tried everything I can think of... short of going over the underside of the board to see if I somehow may have scuffed a trace when de-capping the board.
My question for you-all: what am I not thinking about here, what else can I try. This would be the 1st board that I may have caused a total failure by attempted recap
Thanks for taking the time to check out my dilemma.
Asus A8V Deluxe
Things attempted:
Swapped out CPU
 But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
 But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.  I picked it up last November from someone on my local Craigslist. It wasn’t very close to where I live, but was close to a family friend that I had to go visit anyways. So after watching the posting on Craigslist for a few weeks and seeing it getting...
