Here is a old mobo, Asrock 939Dual-SATA2. Found it due to a friend of mine attic's cleaning, together with 7950 GX2 video card (which is working fine).
The problem is the main board, is not working. I removed everything from it preparing to throw it away (before I will do some soldering lessons on it
Before I start, there is any way to fix it? It is nice mobo, it has AGP slot as well. I tried it to see if works, but when I plug it, not the power button, the fan of PSU & CPU spins a few seconds and stops. When I turn the power button on, the fan of cpu starts ok, and after a few seconds I here continuously bips, I cannot number them because the bips never stops.
It also has burn smell on it. The board looks perfect. Checked every piece, (visually), and no signs of anything that could be the cause of the smell. (the smell of burn it was before the motherboard tested)
The caps, most of them are OST 6.3V 1000UF, 3300uF and 1200uf KZE. All of them looks OK.
Could be the caps?
Bin or not?
Could be the caps?
Bin or not?
