Abit KA7-100
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Re: Abit KA7-100
    Looks much better... thanks for the advice, topcat! Still waiting on the MOSFET to finish the board, though...
    Ludicrous gibs!
    • PeteS in CA
      • Aug 2005
      • 3579
      • USA, Unsure of Planet
      Re: Abit KA7-100
      With an ohm meter, every lead should be "open" or very very high resistance with respect to every other lead. The same should be true with a diode checker except if you connect the "+" lead to the Source and the "-" lead to the drain: that should read like a diode. This assumes an N-channel MOSFET; with a P-channel, the polarity of the diode checker leads would be reversed.
      PeteS in CA
      • dood
        Deputy dood
        • Mar 2004
        • 2462
        Re: Abit KA7-100
        It lives!
        Works great, even with the busted up MOSFET situation... the jumper wire appears to be holding up . It's installing WinXP now, ready to start stress testing!
        Ludicrous gibs!
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16956
          Re: Abit KA7-100
          Nice!
          Well done!
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • Hakuu
            by Hakuu
            Hi There,
            More Details
            TV Model - LG OLED77G1PUA
            07-12-2023, 02:37 PM
          • jb_Bak
            by jb_Bak
            CN6401
            Pin 01 NC
            Pin 02 NC
            Pin 03 "BL_ON": 0V
            Pin 04 "N/C"
            Pin 05 "STBY 3.3V": 3.5V
            Pin 06 "GND": N/C
            Pin 07 "AC_OFF"...
            09-27-2021, 04:52 PM
          • canadaboy25
            Panasonic TC-P54VT25 No image. A or D board?
            by canadaboy25
            I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
            The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
            I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
            01-17-2021, 01:06 AM
