This is the worst board I've had to work on yet... this actually has a MOSFET that got hot enough that it half-desoldered and slid down the board a little. It's a Fairchild FDB7030L, which I ordered a replacement for through Mouser. It has tons of dead caps on it.... I think I'll let the pictures do the talking (see my next post)
Abit KA7-100
Re: Abit KA7-100
Okay, here's the pics so far:
The board as I received it:
this one almost looked moldy! :
Mostly decapped... all the bad ones are gone at least:
Two questions. One, how do I remove all the electrolyte residue from the board, safely? Can I use topcat's washing procedure? Would the fact taht I have a Culligan salt system leave salt deposits on the board afterward? We have high iron content water...
Two, How do I remove the MOSFET from the board? The legs are desoldering, but the chip itself is somehow attached to the board. Do I pry it off, or heat it with a blowdryer, or what?
Thanks,
doodLast edited by willawake; 03-17-2006, 01:52 PM.Ludicrous gibs!
Re: Abit KA7-100
I clean the boards using rag and alcohol.
Desoldering the MOSFET requires a lot of heat - I use 75W soldering gun to heat the tab. It takes pretty long but finally, I can lift it.
Also check the other MOSFETs if they're not shorted (they appear OK but you never know...)
I'd change the smaller caps too (like the one near the chipset) as they appear to be the same crap as the bigger ones.Comment
Re: Abit KA7-100
Yes, the smaller caps are going to be replaced... I'm going to recap most of it first, though, and make sure it works. Then continue on to the other smaller caps. I'm assuming that I should just check continuity across the two posts of each mosfet? Should they be open, or a specific resistance?
BTW- I went with 70% alcohol and q-tips to remove the crud... worked great!
Re: Abit KA7-100
Damage to the board under a fried MOSFET happens often - I have a board that has the copper plate from under one MOSFET almost completely missing - it came off with it (I'll probably need to get a copper square somewhere to solder it there). Yours it not that bad, you only need to be careful when soldering new MOSFET in.
The broken pad can be fixed using a wire - find where it goes (to one pin of the small 8-pin chip - MOSFET driver) and a piece of wire will do it.Comment
Re: Abit KA7-100
KA7's = indestructable. After recapping, I've never had one not work. I think I have pics of a KA7 in as bad of shape on the badcaps.net homepage.
If you're going to use the board, rig a fan to blow on the caps. They get extremely hot otherwise, and that will take its toll even on high-end replacement caps.Last edited by Topcat; 03-17-2006, 06:46 PM.<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team StatsComment
Re: Abit KA7-100
Recapping the KA7 with 10mm caps is not fun..... There's an easier way using 10mm caps though. I've done a lot of them like this before I was able to locate 8mm replacements.
http://root.kabalsrealm.com/index.php?page=ka7_p3<--- Badcaps.net Founder
Team : 49813
Join in!!
Team StatsComment
Re: Abit KA7-100
YMMV, but you can use 63:37 low-melting solder when replacing the FET - it will flow easier and allow easier replacement in the future. The downside is that it may also desolder itself easily if high temperatures are encountered again.Comment
Re: Abit KA7-100
That's what a KA7 looks like redone in Rubies<--- Badcaps.net Founder
Team : 49813
Join in!!
Team StatsComment
Re: Abit KA7-100
Topcat- those are 8mm replacements there, right? I couldn't find any 8mm with suitable specs. How did you get the 10mm to fit in there so nice on the other page? I'm having a hell of a time with these... I'd like to make it look neater, but I can't seem to be able to do it.Ludicrous gibs!
Re: Abit KA7-100
The secret to packing the 10mm caps in there is to set orientation off one cap in one of the end positions of the CPU slot. I always start with the one closest to the AGP, because its easy to eyeball it without other obstacles in the way. Solder the negative lead, making sure the cap's base is as close to the board as it can possibly get, angled away from the CPU slot, just slightly. The set the angle you want (CPU clearance is critical with these fat babies), then solder the positive lead. Then, for every cap in the line, use the angle of the first one for orientation. They are packed in there tight, and I mean TIGHT, but it just takes a little patience, but it'll come out perfect every time.
The Rubies I used in the other board are all 1500uF 10v MBZ's. I even replaced the 2200uF caps with 1500uF caps by the FET's. This caused absolutely no issues, and I've done it dozens of times on dozens of KA7's.
Did you check the FET that desoldered with a diode tester? Most likely it was still good, it just got hot and desoldered itself from the pad.Last edited by Topcat; 03-18-2006, 09:02 AM.<--- Badcaps.net Founder
Team : 49813
Join in!!
Team StatsComment
Re: Abit KA7-100
i always replace any "sliders"i find.
even if they arent shorted i find they have been wounded.high on res and such.
dont worry about the solder type though.
if it gets hot enough to slide again you have worse problems anyway....Comment
Re: Abit KA7-100
I'm going to try to clean up the current cap install if I can. I don't like the looks of the board when there's caps leaning all over the place. I prefer to have nice, neat rows, which I think shows that I care about what I'm doing.
How should I test the MOSFET? I have a multimeter, that appears to be able to test diodes. When I measure across the two legs I get 104... what does that number mean? I get 680 when I test one of the mosfets still on the board, but that could be sending current through other devices on the board as well, right? I'm testing on the legs of the MOSFET itself, btw...Ludicrous gibs!
Re: Abit KA7-100
The actual resistance between Gate and Source is 104 ohms (what the diode test was telling me as well), between gate and drain is 5 ohms, between source and drain is 99ohms. I don't know that this tells me anything, but I'm replacing it regardless.Ludicrous gibs!
Re: Abit KA7-100
Here's an interesting size comparison with this motherboard... New caps vs old caps:
From left to right - New Panasonic 1000uf 10v, old JPCON 1000uf 10v, new Panasonic 1500uf 6.3v, old JPCON 1500uf 6.3v, New Nichicon 2200uf 6.3v, old JPCON 2200uf 6.3v
Now, there's nothing wrong with 8mm caps, but typically they'll be taller than their equivalent spec'ed 10mm counterparts. Here, the 10mm's are bigger in every respect!Ludicrous gibs!
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... -
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... -
by jb_BakHey guys great forum glad to have found it. I bought a Sony XBR 65X900C cheaply because it didn't work. No signs of life at all not even a light/led. All I hear is a brief high voltage sound when I throw the power to it.
CN6401
Pin 01 NC
Pin 02 NC
Pin 03 "BL_ON": 0V
Pin 04 "N/C"
Pin 05 "STBY 3.3V": 3.5V
Pin 06 "GND": N/C
Pin 07 "AC_OFF"... - Loading...
