Foxconn WinFast NF4K8MC power up problem
  • llphat
    • Dec 2010
    • 20
    I have a Foxconn WinFast NF4K8MC motherboard which does not seem to power up if you short the PWR_SW leads. If you however short the PS-ON (green wire on ATX power connector) to ground it will power up and boot without problems. Once powered up, you can switch the board off by shorting the PWR_SW lead for a few seconds, after switching off though it will again not power up if you short PWR_SW, the only way to power up is to short the PS-ON to ground on the ATX power connector.
    Yes I can probably make two switch, one to hot-wire PS-ON to ground to start and the other is the normal switch connected to PWR_SW but it's rather annoying.
    Any clues of what might be wrong? Thanks.
  • Krankshaft
    • Jan 2007
    • 2328
    Re: Foxconn WinFast NF4K8MC power up problem
    Did you try another power supply?
    ATX PSUs have a power good signal (gray wire) they output through the ATX connector if it's not there the mobo may not power up unless you force it directly. A power good signal won't be outputted until all of the rails are within voltage spec.
    • llphat
      • Dec 2010
      • 20
      Thanks for your response.
      I had tried at least two different PSU, with them having either 24pin or 20pin power connectors but the effects are the same.
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        you can try replacing the ITE chip. it is responsible for power on
        Im Back... sort of...
        • czeq
          • Jun 2012
          • czech republic
          how easy replacing this chip, i have EXACTLY same problem, with same motherboard, one day it stop power up, and i have to use wire to power it up manually, connecting green and black wire.
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            i dont think its getting that far.no pg on +5stby.
            something on the board may be telling the system the +5stby is out of range and this blocks startup till you force it on.
            • Calchaqui
              • Oct 2005
              • 112
              Same problem in several mobos, ghetto fix soldering a direct swich. I cant fully understand the root problem
              I LOVE WWW.BADCAPS.NET
              • Calchaqui
                • Oct 2005
                • 112
                One of the mobos with this failure, a Biostar one, has no ITE CHIP whatsoever, it doesnt even has little transistors or discrete components (rersistors, caps) in the PSON trace to atx connector. It is quite clear.
                A MISTERY to me (it powers up directly, but not using the pson panel pins, but powers downs using the pson panel pins)
                Any comment?
                • ala_borbe
                  aka Donald
                  • 1625
                  • Malta
                  you can read here some basic info about SIO and how it works
                  http://translate.google.com/translat...hoat-dong.html
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                  • PantherDave
                    by PantherDave
                    Hi all!
                    05-29-2024, 02:01 PM
                  • GLISIT
                    by GLISIT
                    01-16-2025, 02:29 PM
                    03-31-2024, 02:12 PM
                    09-06-2024, 05:59 AM
