Kworld TV tuner card
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Has Stone 85C 1000uf 16v caps
    Not bad yet, but I'm going to keep my eye on it... it doesn't have that many hours on it yet.
    Ludicrous gibs!
  • Newbie2
    • Sep 2005
    • 885
    Re: Kworld TV tuner card
    Those STONE caps look like they are general-purpose caps.
    My gaming PC:
    AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
    ASUS M4A77TD AMD 770 AM3 Motherboard
    PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
    G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
    TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
    WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
    ASUS Xonar DG 5.1 Channel PCI sound card
    Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
    Antec Three Hundred Mid-Tower Case
    Microsoft Windows 10 Pro 64-bit
    Microsoft Windows 7 Ultimate SP1 64-bit
    • dood
      Deputy dood
      • Mar 2004
      • 2462
      Most likely... we'll see if they become bad So far, they're doing okay.
      Ludicrous gibs!
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        16v seems very excessive. i think you could replace them with 1000uf 6.3 no problem 5v is what the card will see. newbie2 is correct in his observation. might as well replace with low esr caps and see if there is any benefit.
        i am currently enjoying an old pctvpro which under fedora 4.2 is recognised automatically on install and plays immediately via tvtime. so i can watch tv on a monitor next to my main screen. i havent watched movies for several months but now it works well this way as i cant hold my attention long enough to watch only tv.
        kworld and avermedia are quite common here along with pinnacle. i vowed not to purchase another pinnacle as their driver/software support was rather silly as they require installation from original disk before update. Hauppage appear popular and i wonder if they are really any good. Ati Theatrix 550 appears to be the one to get but availability here is lacking.
        • Chris1992
          • Apr 2005
          • 561
          Where did you buy that card, dood? I see a TV tuner that looks identical in Cyberguys catalog, thinking about getting it for TV in my room (antenna only tho).
          The great capacitor showdown!
          • yanz
            • Nov 2004
            • 910
            hmm, well.. my tvcard doesn't even seem to have any elco caps
            yep, i've seen a lot of 16v caps on the vga/pci cards and replacing them with 10v ones is okay. i never try it with the 6.3v though..
            days are so short when you actually do something..
            • dood
              Deputy dood
              • Mar 2004
              • 2462
              Chris- I got mine from newegg.com
              Ludicrous gibs!
              • japlytic
                • Oct 2005
                • 2086
                These capacitors filter the power rails for the card, because there can be induced noise after the power supply, even though it has good filtering. You are unlikely to have problems if you use a power supply with adequately rated electrolytic capacitors for each rail on the output side.
                • kotel studios
                  Philips SAA7134 TV tuner card - requiring drivers and software
                  by kotel studios
                  Sorry if I posted this in the wrong forum.
                  As mentioned in the title I'm looking for Philips SAA7134 TV tuner card driver and software. Sadly I couldn't find anything online. Maybe someone here has them?
                  02-09-2025, 07:25 AM
                • Christos Tsiligiannis
                  Marian Trace Alpha sound card repair help
                  by Christos Tsiligiannis
                  Hello to the forum.
                  My name is Christos, I am new to the forum here and i am posting from Greece.
                  So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                  To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                  So i tried asking for a schematic from the company and they would not give me one. Instead they...
                  11-18-2024, 05:26 AM
                • Kemer
                  Graphics Card mounting frame
                  by Kemer
                  Hello, I removed the graphics card from my laptop and I want to heat it in the oven. What I want to ask is, is it okay to heat the card without removing the metal mounting frame on it?
                  As you can see in the photo, there is a plastic (black) gasket between the metal frame and the card. It sticks the frame tightly to the card.
                  I previously removed the metal frame while heating it, but it is quite difficult to separate it from the surface it is attached to. If there is no problem, I do not want to remove it.
                  What worries me right now is the possibility that...
                  09-14-2024, 08:57 AM
                  HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook Specification for Upgrade or Repair
                  This specification for the HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) boardview and 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon...
                  09-06-2024, 08:30 AM
                • FZG
                  EVGA Nu Audio Sound Card - Not Working
                  by FZG
                  I have an EVGA Nu Audio sound card that is not working properly and I need some help diagnosing the fault (preferably by someone who owns this card and is willing to take some measurements).
                  The card sort of powers up (LED lights are coming on and the relais is clicking, some voltages are present) but it is not detected in Windows. I tried installing in two different PCs and tried several driver versions but the card was never detected anyway. So I thought this is probably not a driver / software-issue and then disassembled the card to take some measurements.
                  I found...
                  03-07-2025, 11:44 AM
