Kworld TV tuner card
    Has Stone 85C 1000uf 16v caps
    Not bad yet, but I'm going to keep my eye on it... it doesn't have that many hours on it yet.
    Ludicrous gibs!
    Re: Kworld TV tuner card
    Those STONE caps look like they are general-purpose caps.
    My gaming PC:
    AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
    ASUS M4A77TD AMD 770 AM3 Motherboard
    PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
    G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
    TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
    WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
    ASUS Xonar DG 5.1 Channel PCI sound card
    Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
    Antec Three Hundred Mid-Tower Case
    Microsoft Windows 10 Pro 64-bit
    Microsoft Windows 7 Ultimate SP1 64-bit
      Most likely... we'll see if they become bad So far, they're doing okay.
      Ludicrous gibs!
        16v seems very excessive. i think you could replace them with 1000uf 6.3 no problem 5v is what the card will see. newbie2 is correct in his observation. might as well replace with low esr caps and see if there is any benefit.
        i am currently enjoying an old pctvpro which under fedora 4.2 is recognised automatically on install and plays immediately via tvtime. so i can watch tv on a monitor next to my main screen. i havent watched movies for several months but now it works well this way as i cant hold my attention long enough to watch only tv.
        kworld and avermedia are quite common here along with pinnacle. i vowed not to purchase another pinnacle as their driver/software support was rather silly as they require installation from original disk before update. Hauppage appear popular and i wonder if they are really any good. Ati Theatrix 550 appears to be the one to get but availability here is lacking.
          Where did you buy that card, dood? I see a TV tuner that looks identical in Cyberguys catalog, thinking about getting it for TV in my room (antenna only tho).
          The great capacitor showdown!
            hmm, well.. my tvcard doesn't even seem to have any elco caps
            yep, i've seen a lot of 16v caps on the vga/pci cards and replacing them with 10v ones is okay. i never try it with the 6.3v though..
              Chris- I got mine from newegg.com
              Ludicrous gibs!
                These capacitors filter the power rails for the card, because there can be induced noise after the power supply, even though it has good filtering. You are unlikely to have problems if you use a power supply with adequately rated electrolytic capacitors for each rail on the output side.
